1980 Corvette power locks
Craig
Dave
The lock actuator is not a special part. Order it from RockAuto. There were at least a half-dozen different brands represented, and you can pick which supplier you want. When you order from a reseller, who knows where the part comes from.
I'll get to fixing the locks eventually. Order of battle:
- Finish reinstalling the rear suspension, 2nd time, hoping that the 2nd set up on the rear end gears eliminates the gear noise and that the now 1st time rebuilt 39 year old TA's eliminate a knocking noise the source of which has not really been identified
- Tidy up a few minor issues such as a better temporary re-plumb bypassing the blown our heater core which I can live without, replacing one of the three studs in the exhaust manifold that holds the down pipe on (idiots who inspected it snapped it off trying to tighten claiming there was a minor leak which I never could hear), etc.
- Take the car out for a couple test drives to see if the gear noise and knocking are gone - avoid the cops since the inspection has run out while the work was being done
- Get the car inspected and have a little fun for the summer while considering engine and transmission options
- Winter - hopefully replace the engine, probably a crate turnkey type, carbureted, 400 hp range, and put in an overdrive tranny (leaning toward a well built 200-4R) and get the front suspension in order
- Have some fun over the summer
- Winter, new paint and maybe the interior - finally maybe a working lock system
