Changing Oil pump
Old Apr 3, 2019 | 10:55 PM
frytex's Avatar
frytex
Default Changing Oil pump
Is it really this hard. Do I have to remove the engine in a 1980 Corvette to replace the oil pump. Are you f***ing kidding me. Why would anyone make it so the entire engine has to be removed to replace the oil pump?
Old Apr 4, 2019 | 12:01 AM
roboto65's Avatar
roboto65
Why are you replacing the oil pump?
Old Apr 4, 2019 | 12:29 AM
TimAT's Avatar
TimAT
If you're going to pull the engine just to replace the oil pump, you're all about doing things the hard way. Drop the idler arm and the oil pan. Done.
Old Apr 4, 2019 | 12:30 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Good question.
Also, no reason to pull the engine. Unbolt the idler arm, drop the oil pan and unbolt the pump and pickup. Easy peasy. Make sure that you put the oil pump drive back in and mesh it with the distributor too.
Old Apr 4, 2019 | 12:31 AM
CA-Legal-Vette
Beat me by a minute Tim. Guess you type faster.
Old Apr 4, 2019 | 05:35 AM
terrys6t8roadster's Avatar
terrys6t8roadster
A C3 corvette is one of the few cars that the oil pan can be removed while the engine is still in the car. T
Old Apr 4, 2019 | 08:19 AM
frytex's Avatar
frytex
That is what I thought. I have changed the oil pump before on other cars. But when I did remove the oil pan, the pump is mounted to the bracket (if you Will) that holds the crankshaft in place at the transmission. The screws that hold the oil pump come through this bracket into the oil pump. Meaning the bolts are not on oil pump but they come down and the treads are in the pump. So I went to YouTube and it says you have to remove the engine. It is a 1980 350 Vette.
Old Apr 4, 2019 | 08:23 AM
frytex's Avatar
frytex
I was driving it and started to hear a noise like a lifter going bad. I just bought this car. Because no one has shown this car any love I thought we'll there is a chance the pump is going out let's go ahead and replace it just to ensure oil is getting moved around. But not if it means removing the engine. So I will just go and work on the knocking sound by itself.
Old Apr 4, 2019 | 08:31 AM
HeadsU.P.'s Avatar
HeadsU.P.
Its really not a bad job. I think the worst is scraping the old gasket off the block.
A tip is to buy a 3/8 drive extra long extension to reach the pan bolts.
If you are pulling the pump, just ten minutes more work and you can change the notorious "Rear Main Seal" leaking issue.
Consider a oil pan stud kit instead of trying to get the bolt holes, gasket & pan to line up. The kit is about $25 and you will wonder how you survived without.
The idler arm bracket has two carriage bolts / nuts. It easily drops down to give you pan clearance. In the event that the pan is fighting you, jog the IGN key. That will move the crank counter weight away from the pan.
And for what its worth. Those old cast iron pumps will go forever. The ticking sound you hear may not be a lack of oil pressure but rather a cam lobe going south. What oil was used, do you know?
Old Apr 4, 2019 | 08:39 AM
frytex's Avatar
frytex
Luckily the gasket came right off. But can I remove the jacket that holds the crank in place where the rear main seal is located while it is in the car?
I feel like if I do this it will drop the crank and then I will not be able to get it back in place. Not sure what oil was used I was going to put 10w 30 back in it.
Old Apr 4, 2019 | 08:48 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It's called the "rear main cap", and NO, the crankshaft won't DROP, as it's held in place by 4 other "main caps". And while you're in there, you might want to replace the OE oil pump drive shaft, the one with the plastic connecting collar that's know to dry out and break, with a driveshaft that has a metal collar. Both Melling and Moroso sell them.
Old Apr 4, 2019 | 08:55 AM
frytex's Avatar
frytex
Old Apr 4, 2019 | 09:02 AM
stingr69's Avatar
stingr69
The oil pump attaches with a single bolt that threads into the main bearing cap. If you remove the bolt the pump will come off but nothing else will be disturbed. If you want to replace the rear main seal, you can remove the 2 rear main cap bolts and replace away. The crank is not going anywhere.
I still worry you may be working on fixing a problem you do not have. Did you check oil pressure before you opened the tool box? I would be looking at the valve train first if the oil pressure was still good. Cams go flat and bearings wipe out much more often as compared to an oil pump wearing out. If it IS an oil pressure problem, you may have to go back in there all over again to fix that issue.
Old Apr 4, 2019 | 09:07 AM
frytex's Avatar
frytex
I did not my oil pressure gauge is reading 0 which is why I thought lets replace it. But it could also be the gauge is bad. But I already have it apart and i bought the parts so I guess I will go ahead and replace it and the rear main seal while I am under the car anyways. And get back to the noise.
Old Apr 4, 2019 | 09:16 AM
leadfoot4's Avatar
leadfoot4
Most likely, unless a previous owner "worked on your car", it's equipped with a hydraulic cam. If you have "zero" oil pressure, or VERY low oil pressure, you'll have 16 lifters clattering quite loudly, followed by a rough running engine, because the lifters have collapsed, due to not being properly oiled. If you are not experiencing anything like that, then you at least have a (somewhat) functioning oil pump. My advice is to fix the oil pressure gauge, first, or hook up a remote gauge under the hood, directly to the engine, to verify what oil pressure you have, to help diagnose your issue.
BTW, how old is your oil filter, and is it a good filter, not a crappy "orange Fram"? Filters can sometimes disintegrate, internally, causing restrictions.
Old Apr 4, 2019 | 09:23 AM
frytex's Avatar
frytex
Since I just bought it I am not sure how old so I purchased a new one since I was replacing the pump already I thought I would just do a complete change out of oil components so that I knew that they are now new and working. Same with rear main seal
Old Apr 4, 2019 | 09:54 AM
jackson's Avatar
jackson
Default Samaritan @ New Braunfels
OP frytex
Good Thinking to be proactive on these matters ... but as stingr69 & leadfoot4 said above ... should have first used a separate remote gauge to verify oil pressure.
Seems there're a few CF members on this forum who reside in New Braunfels area and have applicable experience ... perhaps one might chime in with an offer of handy advice?
To Changing Oil pump
Old Apr 4, 2019 | 10:00 AM
jackson's Avatar
jackson
If you're changing oil pump, suggest you also replace screen & pickup tube with new, correct part.
There's a bit of technique involved with properly aligning & seating that into oil pump.
Old Apr 4, 2019 | 01:16 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
And this would be why you should buy a quality aftermarket pump that has a bolt on integrated pickup tube/screen.
Old Apr 4, 2019 | 01:20 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No such thing in this world unless you spend about $700 on a billet Moroso...... some circle track and drag race pans have a matching pickup that bolts to the pump but the tube still presses into the body of the pump.
Jebby
