Adjusting rear ride height
Old Nov 4, 2002 | 10:45 AM
yogi78's Avatar
yogi78
Default Adjusting rear ride height
I noticed that my ride height is slightly lower on the drivers side rear than the passenger side and wanted to know if the height was adjustable with the stock rear spring.
Old Nov 4, 2002 | 10:50 AM
Bobchad's Avatar
Bobchad
Default Re: Adjusting rear ride height (yogi78)
The spring bolts can adjust the ride height assuming nothing else is wrong. Raise the height on the drivers side by screwing the bolt in or lower the height on the passenger side by loosening the bolt.
VBP has the rear spring bushings and bolts with greater adjustability. You might want to consider changing out the bushings if they are worn. Can be done in an hour on both sides and involved cutting out the old bolts due to rust on mine.
Bob
