454 swap radiator question
Old Apr 13, 2019 | 01:08 PM
Userj8670's Avatar
Userj8670
Default 454 swap radiator question
I have a 1972 Corvette. As the thread states i am doing a 454 swap and made the determination that I need a new radiator. Since I had a 350 I am assuming the big block radiator is NOT a direct swap(given that it is bigger) ?
What are my options for a direct fit alum radiator? I assume i need a new radiator support frame?
Old Apr 13, 2019 | 08:56 PM
hamrad's Avatar
hamrad
I did this to my 1973. I used an aluminum champion radiator and it fit in the support with no problems. Has worked great cooling my 454 swap.
Old Apr 15, 2019 | 09:32 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
What radiator do you currently have? The small block could have come with 2 radiators, a stock aluminum one and a 26.5" one with AC. The BBC radiator is a 27.5" radiator, and would need a new support if you had the small block aluminum radiator.
Old Apr 15, 2019 | 01:38 PM
bashcraft's Avatar
bashcraft
I swapped a zz502 into my '69 and am using the stock small block radiator. It's been working great for over 10 years.
Old Apr 15, 2019 | 07:29 PM
Mooser's Avatar
Mooser
a good SB aluminum rad will be lots for most cases
Just out of curiosity, what are you doing for a hood?
M
Old Apr 15, 2019 | 09:37 PM
Userj8670's Avatar
Userj8670
Hi all-
Made the determination that I will need a new rad as well as red support. My current rad is 23x17 and the car already runs over 200 with my 350.
I have ordered a new rad, rad supoort and all the new brackets etc
I also ordered a L88 hood from Stinger fiberglass.
New wheel bearings going in as well
Old Apr 16, 2019 | 11:47 PM
ronarndt's Avatar
ronarndt
The PO swapped the 327 for a 454 in my 68 convert. He installed an aluminum radiator that fit using the same lower supports and top bracket. The width will be the limiting factor for your swap. Get the thickest (four rows of tubes) aluminum radiator you can get. The 454 generates a lot of heat.
Old Apr 21, 2019 | 08:25 AM
mrichi's Avatar
mrichi
De Witts make a Heavy Duty radiator which will suit your 454 not cheap but a very good product.Also I had to put the rubber style front air dam on it’s the one which suits a 79 Vette with that on no more overheating issues
Old May 3, 2019 | 04:20 PM
godrocksus1@gmail.co's Avatar
I like Champions. Just make sure you reinstall the foam. The nose cone has to be sealed from the engine compartment. this makes sure the air from under the nose goes through the radiator and not around it.
I also changed the thermostat cover to one with a plug in it so that I can bleed the system. It is the highest point.
I made my core support.
Keep in mind if you are going to make one, the hood hinges. I switched to a lift off hood.
To 454 swap radiator question
