Advice on tune up options
Old Apr 20, 2019 | 08:52 PM
Classic Muscle's Avatar
Classic Muscle
Default Advice on tune up options
I'm about to buy every thing to tune up my 77 and could use some advice on what brands of wires, plugs, cap ect to go with. My car still has the factory heat shields installed but I'm not sure if I should use those because I'm going to be replacing the factory exhaust manifolds and installing headers and side pipes in the near future. Don't you need a different set of wires and shorter plugs if you're installing headers? Will the factory plugs and wires still work with headers if I run them through all the factory shields? Sorry for the stupid questions but I just don't want to end up buying wires and plugs twice if I can help it. Thinking about going with all Acdelco but is there a better brand I should consider?
Old Apr 20, 2019 | 10:49 PM
REELAV8R's Avatar
REELAV8R
I use hooker headers with side pipes and NGK plugs with no clearance issues. Straight plug heads not angle plug heads.
you can still use the original routing for the plug wires. Get spiral wound wires for good quality wires.
Old Apr 20, 2019 | 11:27 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I recommend going over the top of the valve covers with the wires and cutting your own........use Taylor pt# 73051....cut to length and crimp one end on.....use Taylor pt#43390 to strip and crimp......I can do a set in 45 minutes. I just think the stock routing is silly and unneeded now as spiral wound resistor wire does not interfere with radio signals.....
I actually like MSD's HEI cap and rotor......super high quality and looks cool. Fits the stock HEI unit. For plugs I use NGK....either UR4 or FR4 for iron or aluminum heads.....the R5671 plugs are even better if you can find them as they come in 4 heat ranges (7 to 10)....I usually go with an "8" on a well tuned engine.
Jebby
Old Apr 21, 2019 | 12:12 AM
Classic Muscle
I don't have my car here at home to look at it again but I don't think I can use the straight ends with the factory exhaust manifolds I think they will touch the manifold. It's gonna be at least a couple months before I can buy a set of Doug's porcelain coated headers and I need the wires now.
Old Apr 21, 2019 | 12:20 AM
Classic Muscle
Jebby
I did not know anything about the spiral wound resistor wire and radio signals thanks for that tip! I was just looking at the MSD stuff too and was kinda really wanting to run the wires over top just wasn't sure if it would be an issue with the stock exhaust manifolds or not.
Old Apr 21, 2019 | 09:09 AM
REELAV8R's Avatar
REELAV8R
Here is some good reading on the subject if you want.
https://www.aa1car.com/library/spark_plug_wires.htm
Old Apr 21, 2019 | 10:58 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
With the stock manifolds...you will have to go around the back of the valve cover and use 90 degree boots.
Jebby
Old Apr 22, 2019 | 03:45 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Sorry for the stupid questions but I just don't want to end up buying wires and plugs twice if I can help it...
FWIW: wait until you have the headers installed, then go from there.
Old Apr 23, 2019 | 02:59 PM
DAD111's Avatar
DAD111
I made my own - used the crimping tool as Jebby said. I also used straight boots at the plugs with stock exhaust manifolds.
Old Apr 23, 2019 | 03:30 PM
Kacyc3's Avatar
Kacyc3
Are you using vortec heads?
Old Apr 23, 2019 | 03:32 PM
DAD111's Avatar
DAD111
Yes 062 Vortec - Straight plugs
To Advice on tune up options
