Car dies when I turn...
Old Apr 22, 2019 | 08:32 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Car dies when I turn...
1975 convertible with automatic transmission and Holley 650 4-barrel.... Happens everytime... cold, hot...turning hard (coming up to a corner quickly) or turning regularly...it doesn't matter. I checked the bowls float levels...right below the sight line...fuel trickles out when I shake the car. Checked the air/fuel mixture with vacuum gauge....vacuum maxed out at 15 inches. The car starts with no problems and runs smooth... the auto choke works. And when I "goose it" while it's parked...no problems....she responds like normal...immediate and smooth. BUT when I drive it and WOT, she hesitates...spits and sputter a little.
Cleaned the carb with Gumout spray...inside & outside while the engine was running (per the instructions on the can) Took her out and the same thing....
Thinking of converting to a TBI system..but man, the COST!!!
HELP!!!.
Old Apr 22, 2019 | 08:58 AM
HeadsU.P.'s Avatar
HeadsU.P.
Nothing wrong with a Holley 650 (bias). Lets blame the Ethanol, its more fun.
Your spraying of carb cleaner is a wonderful thing to do a couples times a year. Unfortunately, it does nothing to the jets which I suspect one of them is plugged with varnish. That would also explain the WOT hesitation. Only one jet is functional. That would also explain good idle and revving characteristics. Also explains the stalling when turning.
So, with that in mind, its time to remove the fuel bowls and soak the metering blocks in a bucket of carb cleaner (Amazon). Remove the Power Valve to avoid any chemical damage.
While you are in there, take note of the floats. Do they seem saturated and are likely sinking? After a good cleaning, install new "blue" fuel bowl & metering block gaskets. Use nothing but genuine Holley parts and you should be good to go.
Old Apr 22, 2019 | 05:37 PM
MelWff's Avatar
MelWff
when you adjusted the mixture screws and were turning them clockwise, did you reach a point with both screws that the idle started to drop?
Do you have a smooth idle with the engine in drive?
did you pull the spark plugs to check their condition?
Old Apr 23, 2019 | 12:38 PM
L-46man's Avatar
L-46man
WHAT IS THE FLOAT LEVEL IN THE HOLLEY?
The symptom may be a low float level.
Unkahal
Old Apr 23, 2019 | 05:34 PM
theandies's Avatar
theandies
May I ask if you have a full tank of gas?
Old Apr 23, 2019 | 09:37 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Do you happen to have a fuel pressure gauge in line with your fuel supply line. I was gettting some irregular performance and I noticed my car was sometimes sputtering out of the blue. I didnt adjust of change anything, it just started happening. I had a pressure gauge after my regulator and thoguht it was the regulator. I added a second pressure gauge just after the pump as another tool to solve the problem. It did.
My fuel pump failed internally. The pin that the arm pivoted on pulled out of the casting. It still worked but i was barley getting 3 psi. So it would run but when I got on it, it would drain the bowls faster than they could keep up. It could be a similar problem for you . If rebuilding the carb doesnt do it, check your pressure. It may not explain the dieing in the turns but you never know
Old Apr 23, 2019 | 09:53 PM
vetteguy75's Avatar
vetteguy75
Unkahal
When I shake the car, a little trickles out. I believe that's the right height
Old Apr 23, 2019 | 09:54 PM
vetteguy75's Avatar
vetteguy75
Yes, I have a fuel pressure gauge installed and it shows 6.5 lbs.
Old Apr 23, 2019 | 09:55 PM
vetteguy75's Avatar
vetteguy75
Yes 3/4 full
Old Apr 23, 2019 | 09:56 PM
vetteguy75's Avatar
vetteguy75
Can you clean the jets once you remove the float bowls? I have jet cleaning brushes. I plan to remove the float bowls only and leave the carb on the car this weekend and clean the jets that way...am I correct in my reasoning?
Old Apr 23, 2019 | 10:28 PM
OMF's Avatar
OMF
When was the last time the carb was rebuilt? If it sat for any period of time it's likely that some varnish or crap has come loose and blocked some internal passages.
They are very easy to rebuild, and I'm sure you'll find a great vid on youtube to guide you through it if you haven't done it before.
Old Apr 23, 2019 | 10:44 PM
vetteguy75's Avatar
vetteguy75
Thanks for your input. Lars (of the Corvette Forum...Carb Guru) rebuilt it about 7-8 years ago and it has been running perfectly since the first day I installed it back. It has been sitting for about a month (really bad weather) and I just now started driving her again. I am going to remove the fuel bowls and metering block, remove the power valve and soak it in some carb cleaner. Also going to clean out the jets...put new gaskets, reassemble and see what happens. Question...if I decide NOT to remove the metering block, can I just clean the jets with Summit Racing Carb jet brushes and some Gunk spray carb cleaner?
Old Apr 24, 2019 | 06:30 AM
Rescue Rogers
Maybe you have water in your tank and its been getting sucked up into your system. I wouldnt think varnish would form from one month of sitting. when you drain your carb, can you catch it all in a glass jar?
When was the last time the fuel filter was replaced?
Old Apr 24, 2019 | 11:25 AM
MelWff's Avatar
MelWff
Default Jets
You cannt clean the jets without removing the metering block, they screw into it and you dont need a brush.
Old Apr 24, 2019 | 12:36 PM
cv67's Avatar
cv67
St. Jude Donor '05
Wonder if your floats are too low, and some passage is getting uncovered when you turn hard?
Try raising them up some see what happens, if it runs good the rest of the time I dont see the need to take it apart.
Old Apr 24, 2019 | 08:15 PM
HeadsU.P.'s Avatar
HeadsU.P.
Absolutely !!!! There is no need to remove the entire carb. Sorry I did not clarify that. But you must remove the metering blocks. That's easy. Might need a tap with a rubber mallet.
Just remove the bowls, clean. Remove the metering blocks and clean. Its easy on a Holley. Take note how the accelerator pump arm goes back together. Clean those jets. Do one set at a time so you don't mix them up. Primary will be different size than secondary.
Also take note how the new gasket should go on the part exactly like the old gasket. If you flip them 180* passages will be blocked off.
Use new blue Holley gaskets. Both the bowl and metering block gaskets are sold in pairs. Check out Summit for those.
Old Apr 24, 2019 | 08:30 PM
OMF's Avatar
OMF
What model carb do you have?
To Car dies when I turn...
Old Apr 25, 2019 | 06:46 AM
vetteguy75's Avatar
vetteguy75
Holley 650
Old Apr 25, 2019 | 06:47 AM
vetteguy75's Avatar
vetteguy75
THANKS!! Will do that this weekend as well as the other suggestions in this thread.
Old Apr 25, 2019 | 06:48 AM
vetteguy75's Avatar
vetteguy75
I believe the float levels are correct....a little trickles out when I shake the car.
