side pipes
Old Nov 5, 2002 | 11:27 AM
bustnu2's Avatar
bustnu2
Cruising
Default side pipes
Can anyone help me with some pictures of some corvettes with side exhaust. Preferably with the Hooker side exhaust system. I'm putting a built 427 (dyno'd at just over 600hp) in my 72' vette this winter and was thinking about going with the Hooker side exhaust sytem. Does anybody have any expierence with them? (fit & installation) Any help would be appreciated...Thanks!
Old Nov 5, 2002 | 12:45 PM
groovyjay's Avatar
groovyjay
Default Re: side pipes (bustnu2)
I did my own sidepipes. I have Stahl sidepipe headers with 3.5" collectors. I have 4" baffles inside the home made side pipes.
Old Nov 5, 2002 | 12:48 PM
bence13_33's Avatar
bence13_33
I am running Hooker Header Side Pipes on my 468ci big block. I really love them, the sound is awesome. I took my mufflers out of the side tubes, so it's essentially open headers through the side pipes. 2 1/8" primary and 4" collectors really let the engine breath :)
Old Nov 5, 2002 | 01:17 PM
Toy4Two's Avatar
Toy4Two
Default Re: side pipes (bence13_33)
Gotta luv them pipes :D :cheers:
Old Nov 5, 2002 | 01:19 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Mine have been trouble free, I would recommend Jet-Hot coating them :cheers:
Old Nov 5, 2002 | 05:06 PM
Chuck Harmon's Avatar
Chuck Harmon
I really like mine!
Open headers vs. uncapped JCL Spiral Baffles
Chuck
[Modified by Chuck Harmon, 12:48 AM 11/6/2002]
Old Nov 5, 2002 | 06:02 PM
fontking1a's Avatar
fontking1a
Sure....Hooker sidepipes and Hooker mufflers...sounds pretty good.
Old Nov 5, 2002 | 06:05 PM
ericshaw's Avatar
ericshaw
Default Re: side pipes (Tater74Roadster)
A-freakin-MEN buddy! :cheers:
[Modified by ericshaw, 4:05 PM 11/5/2002]
Old Nov 5, 2002 | 06:11 PM
Schmucker's Avatar
Schmucker
Default Re: side pipes (groovyjay)
That what I was thinking about trying, maybe making a little money if I can get it simple enough. I was thinking I'd put a bend in, cut it off parallel to the pipe that runs along the car, then a bend under the car, cut it off with about 3inches of straight pipe after the bend, then do another bent piece to go to the headers. The gap between those last two pieces would be filled with either a straight pipe, a cat, or a muffler. Then weld on a couple of mounting brackets to bolt it to the frame or something. Just an idea I was throwing around. Probably do it out of stainles so I wouldn't have to polish them up much to have them look good. Toss a heatshield on there also. Hmm, that would look nice.
Old Nov 5, 2002 | 06:47 PM
Scott78's Avatar
Scott78
'78 small block with the Hookers and Spiral Turbo Specialties baffles.
Awesome sound, tough on the shins if your not careful.
If you click on the sig picture you'll be forwarded to a larger one.
Scott
Old Nov 5, 2002 | 07:20 PM
Clink69's Avatar
Clink69
Here's mine.... Not a bad install...
Chris
:flag
Old Nov 5, 2002 | 08:49 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
Default Re: side pipes (Clink69)
Chris
:flag
:seeya :cheers:
Old Nov 5, 2002 | 10:06 PM
JCL's Avatar
JCL
Nothing like it.......... JCL :yesnod: :yesnod: "Have Baffles.Will Travel"
Old Nov 6, 2002 | 03:34 AM
LS1-Corvette00's Avatar
LS1-Corvette00
Here's mine with Hooker Chromies (No muffs) I will have them Jet Hot
Coated in the future (the chrome work on these pipes is absolutely garbage!)
Old Nov 6, 2002 | 07:32 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Hookers + JCL = :D :D :D :D !
To side pipes
