69 Vette Vacuum
Old May 5, 2019 | 10:23 AM
KJLive's Avatar
KJLive
Default 69 Vette Vacuum
A close friend who is very good mechanically (I am not!), installed 2.02 heads on my 350 CI 69 Vette. (Not the original motor). Before the install, my wiper door and headlights worked fine. For some reason, I no longer have the vacuum I need to operate both of these components. We had a lot of stuff removed during the install and I have no idea what could have been overlooked. I am almost certain that the hoses, etc. are original. I am considering purchasing an upgrade kit to make sure that no hoses are damaged and/or are leaking. Any thoughts or suggestions on what I should consider? It is driving me crazy. To date, I have not had a lot of testing. (leaks, pressure, etc.) Thanks for the help.
Old May 5, 2019 | 11:20 AM
VancouverL71's Avatar
VancouverL71
Best think to do is buy a mighty vac (about 50$) and a cheap vacuum gauge (about 15$). These allows you to test various sections of your system and check leak down. In a perfect system there should be little or no leak down. Others will chime in and correct me but I would think that your particular engine/head set up should have plenty of vacuum to run your system. Obviously an older system will need a bit more vacuum as things get older and can bind a bit (example the complicated hinge set up for the wiper door) More than likely a hose has fallen off or you have a leak (or two) in one section of your system if the hoses are original.
Wilcox has some fantastic schematics for the 1969 for trouble shooting. You will need the schematic to understand the system. If nothing else start with the beginning of the system at the intake manifold and plug off the rest of the system and see what kind of vacuum you are working with. Then move outwards through the system slowly and methodically till you find your problem. Once you are done you will have a complete understanding of the system. Keep in mind the mighty vac will test the smaller components but something as large as the vacuum tank will be a bit large to pump up by hand with the mighty vac.
Good Luck, Pete
Old May 5, 2019 | 12:22 PM
KJLive's Avatar
KJLive
Good Luck, Pete
Thank you Pete!
Old May 5, 2019 | 12:25 PM
3X2's Avatar
3X2
Since neither are working, I would be looking for either a not connected/missing/leaking vacuum hose from the intake manifold to the tank.
Old May 5, 2019 | 01:09 PM
KJLive's Avatar
KJLive
Thank you! I will check that too!
Old May 5, 2019 | 01:31 PM
bfit's Avatar
bfit
Just a rough guess here ,
check the hoses at the tank under DS guard , one may have bee dislodged when engine work was done .
Old May 6, 2019 | 06:35 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The check valve and the filter could have been damaged as well. And check the passenger fenderwell. Thats where the mechanical relay for the wiperdoor actuator is hidden. If you had the actuator off, the main line could be disconnected and that would be big enough to wipe out everything
To 69 Vette Vacuum
