L46 Warm Idle Vacuum
After looking around the internet this appears to be the canister designated for the 350/350 engine. Can anyone confirm?
Lars states "Generally, you want to select a vacuum advance control unit which pulls in its full advance at a vacuum level 2”Hg numerically lower than your engine’s operating vacuum at idle."
I bumped up my idle speed to 800 RPM and am now pulling 14" manifold vacuum.
So do I have a problem, or is this a good canister to use?
I also read up on manifold vacuum for the vacuum advance. I currently have the advance can plugged into ported vacuum, which means it currently isn't even doing what it is designed to do when the car is at idle.
I plan to switch the connection to a manifold source and readjust timing/mixture/idle speed.
Be sure to let us know how the test drive goes!
Wow that is a pretty significant difference! I still need to set timing off of manifold vacuum, but I suspect I will have to back off the timing and not be able to achieve 36 degrees. That's fine to make the car a driver, but it will be good to know my "fun" numbers for when I have some race gas on hand.
I'll probably do some more testing, and I will definitely share what I learn. I'll do my best to take good notes so that what I post here can be useful for others.
The engine has a Holley 4150 style carburetor with 3 manifold vacuum connections. One connection is dedicated to the PCV in the driver side valve cover. Curiously, BOTH of the other manifold vacuum ports join together in a T-fitting near the distributor, and then continue on toward the check valve and vacuum tank.
This seems odd. If the vacuum tank accumulates vacuum it only needs a single source right? My intuition leads me to believe that joining two manifold vacuum ports with a T-fitting doesn't accomplish anything more than using a single port, does it?
Please excuse the varnish on my carburetor. I intend to take everything apart and clean it when I get the chance. I recently got out of the Navy, have a 2-year-old son, and I'm in a masters degree program right now so I don't have infinite time...but I do plan to clean it!
Note the vacuum connections in the picture: distributor vacuum advance is currently connected to ported vacuum; the other two visible vacuum hoses are both manifold (one from front, one from rear) and they join together with a t-fitting.
The vacuum t-fitting I described is not visible. It is located under the blue AN fitting leading to the fuel pressure regulator. The regulator is safety-wired because I'm a former helicopter pilot and it seemed like a fun thing to do at the time.
