ditching the Vac headlight system... kit?
Old May 6, 2019 | 03:09 PM
onaqwst's Avatar
onaqwst
Default ditching the Vac headlight system... kit?
Looking to tear out the stock Vac headlight system and install this kit. Anyone do this and/or other kits that seem to be better? Before I drop the coin on this, just looking for feedback.
https://www.zip-corvette.com/68-78-d...onversion.html
Old May 6, 2019 | 03:18 PM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
What kit?
No link to anything.
I am considering the same move with 2nd project.
Old May 6, 2019 | 03:31 PM
derekderek's Avatar
derekderek
I believe miata or Ford probe motors do the job. Takes some fab skills. But way less expense.
Old May 6, 2019 | 03:39 PM
onaqwst's Avatar
onaqwst
I don't mind dropping the cash and really looking for a easy plug/play setup.
Old May 6, 2019 | 03:50 PM
Gordonm's Avatar
Gordonm
That is a nice kit but pricey and you have to pull the dash out to get to the switch. Richard454 had a kit tha tplugged in and use dMiata motors or probe same thing. I bought the kit from another forum member but Richard was happy with any questions. Much lower in price and it did not require removing the dash. They work great and fast .His wiring is much simpler
Old May 6, 2019 | 03:58 PM
PainfullySlow's Avatar
PainfullySlow
Another +1 for Richard454's stuff. I wanted to do most of it myself but I picked up his harnesses and relays, etc. He also has it so that you can have the headlights stay up when the parking lights are on. Handy for cleaning or if you are showing off halo's, etc.
Old May 6, 2019 | 04:27 PM
C3 Stroker's Avatar
C3 Stroker
I am considering this conversion also, I looked at that kit but now I'm considering this one......https://www.ecklers.com/corvette/196...-392154-1.html
Old May 6, 2019 | 04:36 PM
onaqwst's Avatar
onaqwst
At the moment, my headlight switch is dangling under the dash and I was planning on installing a separate line from the battery/fuse for the kit. Trying to avoid messing with the fuse panel because I know where that will lead to. I will contact 454 and see about his kits....
thanks
Old May 6, 2019 | 04:48 PM
Richard454's Avatar
Richard454
thanks
Shoot me an email richard454 at comcast dot net
No need to wire anything to the fuse box and/or passenger cabin- power (at alternator)- ground at radiator shroud and it plugs into the OEM harness on the low beam headlight. No external control box to mount or get wet. No need to take apart the headlight assembly either- as the threaded rod screws right into the OEM clevis.
I have a PDF for the DIY or the complete kit install PDF
Old May 6, 2019 | 11:33 PM
onaqwst's Avatar
onaqwst
Bought a kit from Richard... thanks for the suggestions....
Old May 7, 2019 | 06:49 AM
74_stingray's Avatar
74_stingray
C3 of Year Finalist (performance mods) 2019
St. Jude Donor '19
You will be pleased with Richard’s kit.
Eddy
Old May 7, 2019 | 08:40 AM
BEJ's Avatar
BEJ
Another recommendation for Richard's kit. Very easy install and the headlights work perfectly.
Bryan
Old May 8, 2019 | 04:14 PM
Dave Kalnuk's Avatar
Dave Kalnuk
3rd Gear
I installed a kit from JS Engineering. Works as promised, eliminating all of the vacuum hoses and actuators. Installation was simple, but I did it with the motor and rad out. It could be done with the motor in, but I think you would at least want to remove the rad.
Old May 8, 2019 | 04:39 PM
Richard454's Avatar
Richard454
These- require a bunch of wire splicing- and a little slow...,.
Old May 8, 2019 | 09:05 PM
74_stingray
St. Jude Donor '19
Mine, using Richard’s kit.
Old May 10, 2019 | 06:20 PM
Crimson Thunder's Avatar
Crimson Thunder
I just installed Richard's kits last week. Easy to install and works perfect.
Old May 10, 2019 | 07:31 PM
OldCarBum's Avatar
OldCarBum
Please post pics of the install and your comments when you are finished.
To ditching the Vac headlight system... kit?
Old Jun 6, 2019 | 02:18 AM
onaqwst's Avatar
onaqwst
Took me about 2-3 hours to install the kit. I removed the hood and went to work. I'm sure it would have been faster, but I was taking my time. I need to extend the Red wire about 12" just to tuck it away better, but othr than that, it was easy install.... really glad I did it, been fighting those lights/vacuum for years.......
Old Jun 6, 2019 | 11:24 AM
OldCarBum's Avatar
OldCarBum
Thanks for sharing.
Old Jun 6, 2019 | 02:40 PM
scottjamison's Avatar
scottjamison
Did you have the radiator in or out when you did yours?
I just emailed Richard to buy a kit as well.
