questions on timing
Old May 10, 2019 | 10:01 AM
wgrea3's Avatar
wgrea3
Originally Posted by drwet
Yes its possible, but it probably means someone has been in there before, or one of your springs is broken. Get a kit with a selection of springs and start experimenting. Set your initial timing at 15 degrees advanced and play with the springs until you get the desired all in by 3000. Come back and tell us how amazing the improvement is. Then you can start playing with the vacuum advance. (As Verysoon pointed out, make sure your vacuum advance is connected to manifold vacuum, not ported.)
Amazon Amazon
Does that look reasonable?
Old May 10, 2019 | 10:24 AM
drwet's Avatar
drwet
It looks reasonable, although I would probably stick with a name brand. Check this out:
https://www.summitracing.com/int/par...make/chevrolet
You probably don't need the weights. In my experience the factory ones work better. Just use the springs.
