One lifter bore freakishly tight: now what?!?
I tried to get both heads on, lifters in, pushrods and rockers installed today but I had one rocker left and then I realized it’s never sitting back down on the base circle (this was the bore that was too tight earlier, too).
It goes in 2/3rds of the way and 3/4 of the way if I push down on it really hard but it doesn’t go all the way down and it’s not right.
This, the oil pan, and the intake are all I have left on the engine and it’s killing me.
I grabbed some 60 grit and put it around the lifter and gave it a few cranks, then 100, then 180, finally wire wheel on the bench grinder. Cleaned it a gazillion times and made sure there was no sand in the wheel bearings put it back in; still tight...
Just not sure whether it’s tight at the top or bottom of the bore and assessing the bore at this point means starting all over and I’m avoiding that like the plague...
I need some magic.
Adam
I need some magic.
Adam
First ... any adjustment is typically done to Bore Not lifter.
Quit sanding/rubbing until after you mike what you have. Mike Several & compare.
Maybe the lifter has a burr/nick ... maybe the bore has a burr/nick
What kind of lifters? Roller? PICTURE?
There is some kind of damage inside the lifter bore. Happens sometimes when a cam goes bad and a lifter is damaged. Forcing a damaged lifter up and out of the bore does the damage. Scope the bore and see what damage is there. If it is a nick or burr as stated before then you may be able to clean the lifter bore without taking the engine down.
rickimvette (05-14-2019)
The lifters should have been test-fit into bores Before the first main shell was ever put in block ...
... I say that Not to rub salt in the wound, but to advise the next fellow who's planning a build.
Don't hone anything until you KNOW what & where the problem is.
Gaging ain't worth the boxes they came in until you learn technique to use 'em.
Try Process of elimination.
Mark each lifter pair and map-out & mark each lifter bore and use a tabular sheet to track your work.
Methodically: Swap ALL lifter pairs around ALL lifter bores ... feeling for tightness ...
... that way you might help determine if it's a bad lifter or a bad bore.
If a particular lifter pair is tight in ALL bores, then that particular lifter pair likely has a problem.
If ALL lifter pairs are tight in a particular bore, then that particular bore likely has a problem.
Once you've narrowed-down the number of culprits, then closely inspect/measure.
Disassemble the engine and take it to somebody that can hone that lifter bore correctly. Then clean out oil passages and start over.
SH-60B (05-13-2019)
Its this bore that’s too tight.
Adam
Too much money is invested in the expense of an engine build to sand/grind anything while the engine is half together. More damage will be done by metal particles getting into the bearings. Tear it down and get it to a machine shop to be mic'd and corrected properly. Why risk ruining a new build just to save a few bucks? It'll be worth it later on down the road for peace of mind too.
SH-60B (05-13-2019)
To make matters worse, I noticed that one valve guide plate is cracked in three places too. (I used a torque wrench and tightened it to spec, so no idea why it happened but I need to get another one of those now...)
I sure am paying a LOT of stupid tax on this engine build; I’d like to think that means I’m getting smarter quickly.... (please, please, please...)
Adam
No I didn’t try to bend it at all; once I remove it I’ll take a look at the bottom and see if there’s some random metal slag on the bottom or something. The only thing I can think of is that when I unscrewed the stud maybe some locktite chunk came up out of the threads and fell between the guide plate and the head or something like that.
Im really surprised they’re so brittle but I guess the harder they are the more brittle they are...
Adam
