Air Conditioning Band Aid
Old May 18, 2019 | 12:28 PM
Michael McClay's Avatar
Michael McClay
3rd Gear
Default Air Conditioning Band Aid
Hello Everyone,
I just bought a 1968 convertible this January and i'm really excited about it. It has alot of options, one being the AC - which of course doesn't work.
It has the L79 327/350 and i plan to do some work on the top end to get it up to around 420, however that won't be until the driving/show season is about over. The problem is that I live in South Georgia and its HOT. I would really like to have some AC blowing, but i don't want to pay alot of money to then turn around and have to let all the R-12 out when i redo the motor.
I was wondering if it is "safe" to use something like AC Pro just to hold the system over until i dress the engine. I know AC pro is R-134A and it can cause some seal leakage, but the question is will that permanently damage the seals? Or will it just cause the AC Pro to not be as effective?
If it just ends up being moderately less effective, but overall not damaging it would bring some much needed relief. If it does cause damage I might just have to suffer because I don't want to have to rebuild the system, although that is a possibility regardless.
If anyone has some wisdom they would like to share i'm all ears.
Thanks,
Old May 19, 2019 | 09:13 AM
VERYSOON's Avatar
VERYSOON
If you introduce R134a into your R12 system you will totally screw up your system components. Also, at a minimum you are going to need to reseal your compressor if your system has not been working for a long time. Then you will also need to replace the receiver/dryer. Wait until you have done your engine mods.
VS
Old May 19, 2019 | 06:24 PM
carriljc's Avatar
carriljc
I have converted several R-12 systems to R-134a. Every one of them worked just fine. You can go to a air conditioning website for vehicles and ask there.
From what you are describing I suggest that you would be better off finding some R-12 until you make a decision of which route you wish to take. You want to avoid mixing the coolants so if you just want to have a "some" cooling, then I would try it with R-12.
Later, when you decide to really fix the a/c you'll have the more difficult decision of either fixing the stock system or buying an aftermarket system.
Old May 19, 2019 | 06:35 PM
fishslayer143's Avatar
fishslayer143
mixing R134 into an R12 system is a bad idea.. [ to clarify, r134 and mineral oil from r12 will not mix.. you will burn your compressor] add R12 if you can find some and see if it will cool, probably not. or wait and convert it to R134.. its not difficult. All seals need converting and new Dryer, etc along with thorough system flush .. rebuild or replace compressor .. you can also upgrade your blower to a C4 wheel for 30% more airflow ... Nothing worse than a C3 in traffic in high humid heat
Old May 20, 2019 | 07:40 AM
derekderek's Avatar
derekderek
it is gonna need seals anyway. they are 50 years old. i betcha there is no R12 left in there. the 134 may stay in 1 day. may stay in 2 weeks. it is not a daily driver. i have been adding 134 to partially charged and fully discharged 12 systems since they made R-12 available by prescription only. does the system show any pressure at all? does compressor come on? if you hot-wire compressor, do you get any cold? only run it hot wired for a few seconds.
Old May 20, 2019 | 08:04 AM
stingr69's Avatar
stingr69
The A/C needs new O-rings at a minimum so why not just fix it first? Use the 134a compatible seals and you can still use them with R12.
No real need to empty the system later. Just disconnect the bolts, set the pieces to the side and pull the engine.
Old May 20, 2019 | 12:19 PM
GUSTO14's Avatar
GUSTO14
At the very least, before you introduce any 'Freon' into the system, have someone with a vacuum pump try to pull a vacuum on the system.
It may save you a bunch of money and some aggravation if there is a leak (really, is there any doubt) and all your 'Freon' just goes up in the clouds. If it does hold a vacuum it may be worth introducing some refrigerant into the system.
Good luck... GUSTO
Old May 20, 2019 | 02:22 PM
REELAV8R's Avatar
REELAV8R
R12 and 134A have NO compatibility issues. The problem lies in that PAG used in 134A systems is not compatible with mineral oil used in R12 systems.
so to answer your question yes you can put 134A in anR12 system with no ill effects.
If you try to run only 134A with only mineral oil in the system it will not work for long. 134A will not carry mineral oil, therefore the compressor would soon seize.
this is where ester oil comes in. Ester oil is compatible with both Freon types and can be carried by both types and is compatible with both mineral and PAG oil. However no PAG should ever be mixed with mineral oil, whether ester is present or not.
in a 134A conversion where the system is not completely flushed of mineral oil ester oil is therefore used. In this type of conversion R12 and 134A Freon could be mixed with no compatibility problems.
this is all irrespective of the pressures in the system. System pressures will rise as 134 is added. Only talking about compatibility issues.
Old May 21, 2019 | 07:44 AM
derekderek's Avatar
derekderek
if you put a vacuum on a system, will it evacuate the old oil? if not, is there a low spot it accumulates that can be unhooked and drained?
Old May 21, 2019 | 12:34 PM
REELAV8R's Avatar
REELAV8R
No it will not. If the system still has pressure and you try to vent it some oil will escape unless you vent it verrrry slowly. otherwise oil will stay in the system.
To Air Conditioning Band Aid
