"71 headlight switch?
Old Nov 6, 2002 | 12:34 AM
vettedreams's Avatar
vettedreams
Default "71 headlight switch?
Can someone tell me how to separate the headlight switch **** from the rod ? thanks
Old Nov 6, 2002 | 12:36 AM
71'AirStrike's Avatar
71'AirStrike
Default Re: "71 headlight switch? (vettedreams)
broke mine in trying. bought a new one.
sorry im no help.
good luck
Old Nov 6, 2002 | 07:23 AM
jerryp58's Avatar
jerryp58
I'm probably going in again this weekend, but I've been there before on switches for a couple of different cars (including my Corvette).
There's a release button on the back (sometimes the side) of the switch. Depress that button and then pull the **** out. Depressing the **** and pulling the switch don't require much effort, so don't force it.
Good Luck.
Whoops! Just reread the post and I don't think that was quite what you were asking. I don't know if/how the **** comes off the rod :confused:
[Modified by jerryp58, 6:25 AM 11/6/2002]
Old Nov 6, 2002 | 07:29 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: "71 headlight switch? (jerryp58)
Don't think the **** is designed to come off the rod. It's pressed/swedged/glued on. As JerryP58 said, there is a release button on the switch. It's small. You push it in, hold it, and then pull the rod out. Chuck
Old Nov 6, 2002 | 07:31 AM
Graemeinvette's Avatar
Graemeinvette
I just bought a new **** and it comes attached to the rod. Jerry is right about the release on the switch. :cheers:
Old Nov 6, 2002 | 11:56 AM
vettedreams
Default Re: "71 headlight switch? (Graemeinvette)
There"s a wealth of knowledge on this forum, thanks again!
To "71 headlight switch?
