Vacuum Leak - Smoke Machine?
Old May 22, 2019 | 04:19 PM
Parodi Cigar's Avatar
Parodi Cigar
Default Vacuum Leak - Smoke Machine?
Here is a link to a video showing how to make a smoke machine:
Has anyone tried something like this to find a vacuum leak in a C3's headlight/wiper system? Seems like a great way to spot a leak, fast.
Any thoughts on why it would be a bad idea to remove the vacuum line from the manifold and gently pressurize it with such a smoke generator to find a vacuum leak?
Thanks for your thoughts on this!!!!
Old May 22, 2019 | 04:44 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I used one before on my C3, but not that one. Mine worked great and found two leaks in about 90 seconds.
Old May 22, 2019 | 05:06 PM
Dave J's Avatar
Dave J
If you happen to have a Mityvac or similar all the tests on a vacuum system can be made with a fireworks punk or incense stick. Simply pump up each component and pass it over the part. Doesn't take much smoke. Works like a champ.
To Vacuum Leak - Smoke Machine?
