Heavy Duty ball joints
Old May 24, 2019 | 06:14 PM
cottoneg's Avatar
cottoneg
Default Heavy Duty ball joints
Did a search and didn't turn up much. Is there any such thing as heavy duty ball joints. I got MOOG last time but didn't last too long. I do track the car, so maybe they could not take the stress.
Old May 25, 2019 | 12:17 PM
MelWff's Avatar
MelWff
this site lists a Moog Racing ball joint
https://www.duntovmotors.com/vintage...suspension.php
Old May 25, 2019 | 04:07 PM
redvetracr's Avatar
redvetracr
Originally Posted by cottoneg
Did a search and didn't turn up much. Is there any such thing as heavy duty ball joints. I got MOOG last time but didn't last too long. I do track the car, so maybe they could take the stress.
you want MOOG ball joints out of a MOOG box not from a kit, for the uppers you want the top hat style, the lowers (I think) have a number stamped into them, Gary gtr1999 can tell you what to look for, mine lasted 36 vintage races (and probably more) but I sold my three cars
Old May 26, 2019 | 06:12 PM
MelWff's Avatar
MelWff
arent RS350 and RS352 NOT in kit?
Old May 26, 2019 | 06:43 PM
redvetracr's Avatar
redvetracr
those are not the numbers on any of my MOOG boxes....
Old May 26, 2019 | 07:26 PM
jb78L-82's Avatar
jb78L-82
Moog Suspension components are top notch and should last a long time even if you race the car: Grease the upper and lower ball joints before every race session and they will last a long time......
Problem Solver - Powdered Metal Gusher Bearing For Better Lubrication
MOOG® Problem Solver® products incorporate proven design and engineering features for like-new suspension, ease of installation and longer life. MOOG is the preferred steering and suspension parts brand of professional technicians and NASCAR Crew Chiefs.
  • Powdered metal gusher bearing design enables grease to flow through bearing to stud for reduced friction and enhanced strength
  • Engineered steel composition results in a stronger component
  • Full ball metal stud provides 360° of smooth rotational movement for more responsive steering
  • Greaseable socket reduces corrosion and wear by allowing new lubricant to flush contaminants
  • Loose or worn chassis parts can lead to premature tire wear
MOOG® Problem Solver ™ - Ball Joint Bearing Failure
MOOG® Problem Solver ™ - Ball Joint/Tie Rod Stud Failure
MOOG® Problem Solver ™ - Greaseable Design
Stud Material Information
Stud Design
Ball Joint Boot Installation
Chassis Part Maintenance
MaterialNeoprene
Castle Nut IncludedYes
Suspension Grade TypeStandard
Cotter Pin HoleYes
Mounting Hole Quantity2
AdjustableNo
GreasableYes
Mounting TypeBolt-on
Alternate/OEM Part Number(s): 3749309, 3758406, 3813206, 3819244, 3832162, 3846266, 3865828, 3865829, 3886420, 3886422, 3917822, 3918839, 3918840, 9742108, 9762019
MOOG Warranty Information:
Limited lifetime
MOOG K6035 {Click Info Button for Alternate/OEM Part Numbers} Problem Solver - Powdered Metal Gusher Bearing For Better Lubrication Info
Front Lower
$28.79
Add to Cart
MOOG K6034 {Click Info Button for Alternate/OEM Part Numbers} Problem Solver - Powdered Metal Gusher Bearing For Better Lubrication Info
Front Upper
Old May 26, 2019 | 07:43 PM
stingr69's Avatar
stingr69
Probably just low friction circle track pieces. Other manufacturers make them. Think some are rebuildable.
Old May 28, 2019 | 01:10 PM
cottoneg's Avatar
cottoneg
Thanks guys! I didn't know MOOG made so many different ball joints.
Old May 28, 2019 | 01:18 PM
gkull's Avatar
gkull
I just bought all my moog ball joints from summit racing
To Heavy Duty ball joints
