Vacuum override switch the keeps headlights open does not work
Old Nov 6, 2002 | 09:25 AM
DaddyO's Avatar
DaddyO
Default Vacuum override switch the keeps headlights open does not work
Vacuum override switch the keeps headlights updoes not work.......any ideas?
Wipers work ok. Headlights go up and down fine with the headlight switch.
Old Nov 6, 2002 | 10:20 AM
Bobchad's Avatar
Bobchad
Default Re: Vacuum override switch the keeps headlights open does not work (DaddyO)
As I recall it simply releases the vacuum when pulled down. This allows the headlights to go up. Try pulling the line that goes to the headlights, rather than the line that comes from the light switch, and see if the headlights go up. If it does, try reversing the lines. If that doesn't work you may need to replace the switch.
Bob
Old Nov 6, 2002 | 10:21 AM
DaddyO's Avatar
DaddyO
Default Re: Vacuum override switch the keeps headlights open does not work (Bobchad)
Replace the headlight switch? or the vacuum override switch?
Old Nov 6, 2002 | 11:30 AM
Stewart's74's Avatar
Stewart's74
The vac override switch is a cheap and quick repair. I did mine in about 10 minutes.
Old Nov 6, 2002 | 12:11 PM
DaddyO's Avatar
DaddyO
Default Re: Vacuum override switch the keeps headlights open does not work (Stewart's74)
I can't find the part in the ecklers catalog. Any leads?
Old Nov 6, 2002 | 12:42 PM
Wrencher's Avatar
Wrencher
Typically, the only thing that goes wrong with the vacuum switch is it starts to leak, and the headlights stay up. Did it ever work? I suppose it could be plugged, but I suspect it's a hose routing problem. You can't easily get to the headlight switch and I suspect that the problem is below that anyway. I'd crawl under the dash (easier said than done!), check under the hood and see how the hoses are routed. On mine I can still see the color code on each line and I just followed them and hooked them up per the manual. They were all disconnected for both the wipers and headlights and in a box.
Hans
Old Nov 6, 2002 | 02:16 PM
Stewart's74
DaddyO,
I got mine from ZIP. Go to the restoration store link on the top of the page.
To Vacuum override switch the keeps headlights open does not work
