Darn Brakes Again
Old Jun 7, 2019 | 01:05 PM
  #41
Street Rat's Avatar
Street Rat
Originally Posted by Bikespace
Awesome! Now go drive the hell out of it!
Thanks Bikespace.
Unfortunately I'm headed out of town today for a graduation ceremony.
Old Jun 7, 2019 | 01:47 PM
  #42
cagotzmann's Avatar
cagotzmann
Originally Posted by Street Rat
4. Patience. Some of the evacuated calipers took quite a bit of time to get ALL of the air out.
Craig
There is also 1 more thing that most don't do, but I have always done.
1. when you replace a caliper I also press in the brake pads and shim/wedge between the brake pad and rotor to force the caliper piston in as far as it can go. Then fill the caliper and bleed.
Most of the air gets trapped in the caliper piston bores. The only way to completely bleed this out is force the caliper piston in, Shim/Wedge them in place or use a vise grip, then apply pressure at the MC and bleed.
You can do this at any time. You will be surprised how much air can be left in the piston bores. If you bleed the calipers off the brackets and stand straight up you get the same results, but this is a lot of extra time to complete.
So when I bleed calipers I always press the caliper piston in and shim/wedge/vise grip.
Old Jun 7, 2019 | 02:08 PM
  #43
74_stingray's Avatar
74_stingray
C3 of Year Finalist (performance mods) 2019
St. Jude Donor '19
Test drove her this morning and the brakes are great.
This is the firmest brake pedal that this car has had in the six years that I've owned it.
The problem was definitely too much air in the system.
I contribute the good pedal to the following...
1. A thorough bench bleed of the master cylinder in a level, tilted forward, and a tilted rear position.
2. A thorough bleeding of the system following the correct bleeding procedure. The system had a moderate amount of air in it. Particularly in the Wilwood right front caliper.
3.Lifting the rear of the car as cagatzman showed in a previous post, and forcing air out of the rear of the master cylinder reservoir. I actually didn't expect to get anymore air bubbles after the mc bench bleed. To my surprise I got two more air bubbles out of the back reservoir.
Thank you all for following the seemingly endless saga.
Craig
Fantastic! I am glad to hear that you were able to get the air out, congratulations. Go drive that beautiful Corvette.
Eddy
Old Jun 7, 2019 | 02:40 PM
  #44
Street Rat's Avatar
Street Rat
I tried this on one caliper. I must not have the correct tools. I just made one hell of a mess trying.
Your tips have helped me tremendously!
Craig
Old Jun 7, 2019 | 03:41 PM
  #45
Fredtoo's Avatar
Fredtoo
An additional brake bleed after the brakes have been bedded in and have gotten hot is a good way to get rid of the small bubbles that were hiding in the system.
Old Jun 8, 2019 | 09:38 AM
  #46
Street Rat's Avatar
Street Rat
Eddy
Thank you Eddy!
Old Jun 10, 2019 | 12:43 AM
  #47
Goody's Avatar
Goody
Congrats.. perseverance has paid off for you.
Old Jun 12, 2019 | 08:44 AM
  #48
Street Rat's Avatar
Street Rat
Default Purchased a New Tool
After this last brake fiasco I decided to purchase this tool to spread the pads.
Amazon Amazon
Has anybody used or is using one of these?
Does it do the intended job well?
Craig
Old Jun 12, 2019 | 08:51 AM
  #49
Street Rat's Avatar
Street Rat
I'm going to use the new tool that I purchased (post #48) to do this in future.
Craig
Old Jun 12, 2019 | 10:40 AM
  #50
cagotzmann's Avatar
cagotzmann
https://www.amazon.com/Lang-Tools-27...omotive&sr=1-1
Craig
I am to lazy to remove the center pin to use a tool like that but it should be able to spread the pads since they move easily inward, then I use some of these to shim wedge.
plastic putty knife.
https://www.homedepot.ca/product/a-r...set/1000727514
Usually use 2 on new pads on each side of the center pin to keep the pads between the rotor and the pads.
To spread the pads I just use a vise grip at the center pin location to move the pads in.
