Fuel Pump lever travel
Old Jun 4, 2019 | 04:16 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Fuel Pump lever travel
After a few years of hiatus I am back putting together my '80. A ton of rewiring to do but I wanted to get it running again first. I took the fuel pump off last year and took it apart to check it over, now I'll be damned if I can't remember how much travel the fuel pump lever moves on the cam lobe. Seems like it is only moving a little bit, maybe 1/4 in.
Now I am scared to start it in case that isn't enough. I looked it up and found the travel to be 10 mm. Doesn't sound like a lot to me. I just completely forgot as I usually just bolt them on. Any help here is appreciated.
Old Jun 4, 2019 | 04:22 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Not sure what your question is. The fuel pump pushrod does move very little. Rember that it moves with each cam cycle so half engine rpm. That’s a lot of pumps.
Old Jun 4, 2019 | 06:16 PM
MotorHead's Avatar
MotorHead
Thank-you, my guess is I never really pushed the lever in, I just put the new on figuring it has to be good.
Old Jun 4, 2019 | 07:09 PM
TimAT's Avatar
TimAT
It travels just enough that if the pushrod is on the fat side of the cam it's near impossible to get the fuel pump back on.
Old Jun 5, 2019 | 12:34 AM
gkull's Avatar
gkull
I'm not at home, so I can't take a picture of a cam and the fuel pump lobe. But it is much smaller than the valve lobes
Does anyone have a cam to post a picture?
Old Jun 5, 2019 | 07:45 AM
derekderek's Avatar
derekderek
If smaller than valve lobe, 1/4 is about right. .500 cam is .3333 lobe lift.
Old Jun 5, 2019 | 08:41 AM
jackson's Avatar
jackson
but with much longer duration
To Fuel Pump lever travel
