Installing Allen's exhaust system
Old Jun 13, 2019 | 11:56 AM
Novusuhu's Avatar
Novusuhu
Default Installing Allen's exhaust system
Hey everyone
I'm installing my exhaust system from 'Allen's Exhaust'.
It's a 2.5" true dual system for a 77. I will cut the front 'manifold pipes ends', because I'm running longtube headers.
There wasn't any manual on how to fit the pipes... So I don't know which pipe goes where (LH and RH?).
Is the system (see picture) put together the right way?
Old Jun 13, 2019 | 12:36 PM
BKbroiler's Avatar
BKbroiler
If you're running long tube headers you can throw the front pipes away. You will need a short length of pipe custom made for each side to fit from your collectors back to the pipe at the trans cross member. Also, in case you don't know, you will need a bracket that bolts to the rear trans mount to support both pipes where they pass thru the openings in the cross member. I got one from Mid America. Otherwise the pipes will rattle.
Old Jun 13, 2019 | 12:48 PM
Novusuhu's Avatar
Novusuhu
Ok, can I do the bending myself at home (what are the possibilities)?
All exhaust workshops ask about 60 dollar/hour minimum (Belgium) when working on a car...
Old Jun 13, 2019 | 01:52 PM
BKbroiler's Avatar
BKbroiler
That's good. Can you weld the pipe to the header reducer that bolts to the header collector?
Old Jun 13, 2019 | 03:34 PM
Novusuhu's Avatar
Novusuhu
I can yes.
What was the product number of the special bracket for the dual exhaust system that you use?
Old Jun 13, 2019 | 04:26 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The system looks right but what we do is put the rear in place, then add the front pipes which will give you an idea relatively where the header will intersect the front pipe. Once we know where the end of the header pipe is going to intersect the original style header pipe, we then cut it, mock up the pipes and weld the header collector to the front pipe. We also use the 1973 rear hangers when we do this installation because they are user friendly.
Lastly... make sure you have the tip past the bumper cover, if you don't you'll melt it.
Willcox
Old Jun 13, 2019 | 10:45 PM
carriljc's Avatar
carriljc
Novusuhu
Do you have an automatic or a manual transmission?
I can yes.
Old Jun 14, 2019 | 03:41 AM
Novusuhu's Avatar
Novusuhu
Originally Posted by carriljc
Novusuhu
I have an automatic (th350).
Old Jun 14, 2019 | 12:37 PM
BKbroiler's Avatar
BKbroiler
I can yes.
I looked it up at Corvette Central. Their part # is 323078, $42. This is for 2.5 inch pipes.
Old Jun 14, 2019 | 03:31 PM
carriljc's Avatar
carriljc
Here you are.... even has a picture in the link:
https://www.corvettecentral.com/c3-6...78%26count%3d9
Old Jun 14, 2019 | 04:39 PM
0Willcox Corvette
Former Vendor
Here is the bracket they are talking about. You will need this to do this install correctly. I'm assuming you are 2.5 inches wide at the tranny too..
https://willcoxcorvette.com/catalogs...exhaust+hanger
To Installing Allen's exhaust system
