headlights wont turn.
Old Nov 7, 2002 | 05:15 AM
kingdavidrules's Avatar
kingdavidrules
Default headlights wont turn.
when i turn the headlight switch on the headlights do go on but in the closed position. they never rotate. isnt there a manual way to turn them ? what schould i check first ? the 78 thanks you.
[Modified by kingdavidrules, 4:16 AM 11/7/2002]
Old Nov 7, 2002 | 06:17 AM
FastGlass79-85's Avatar
FastGlass79-85
Default Re: headlights wont turn. (kingdavidrules)
:seeya You can pull them uo manually by getting your fingers under the front edge and picking up, or reaching underneath from the bottom in front of the airdam and pushing up on the center linkage bar. :yesnod: If they go back down after starting the engine, check the manual override switch under the steering column. It maybe in the wrong position. Then check for Vacuum going to the relays located in the front. should toggle off and on with the operation of the headlight switch :yesnod: Problem can be anything from loose vac hose, bad headlight switch,bad vac relay, bad actuators..... :rolleyes: But start with the Vacuum being present first :yesnod: :seeya
Old Nov 7, 2002 | 08:27 AM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: headlights wont turn. (FastGlass79-85)
wow, 1st reply and all the answers you need! :cheers: let us know if it still dosent work.
Old Nov 7, 2002 | 06:36 PM
kingdavidrules
Default Re: headlights wont turn. ('79ProwlerOrange)
the car is stored about 30 min from my house . ill be there tomorrow to check it out and let yall know what goes on .
To headlights wont turn.
