Proper oil pressure for C3
Old Jun 16, 2019 | 10:10 AM
Richard Blanchard's Avatar
Richard Blanchard
8th Gear
Default Proper oil pressure for C3
Can anyone tell me what a typical oil pressure is for a 79' C3 350 small block? At idle and at driving RPM.
Old Jun 16, 2019 | 10:16 AM
F22's Avatar
F22
Depends on the oil pump. Could go as low as 20 at idle and between 60 to 80 at RPM. That's for a Melling High Pressure, High Volume Oil pump. It will always drop at idle, because it's driven off the camshaft.
Old Jun 16, 2019 | 11:35 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
It also depends on the viscosity of the oil and the accuracy of the guage. When my other SBC motors are hot and idling with 10w30 I have seen almost no readable pressure on some guages but it would jump up as soon as the pedal was touched.
A good rule of thumb is 1 lb for every 100 rpm. so 7 lbs at idle and 50 at 5000 rpm but your pump may top out at 30 to 40 psi. If you are not running high RPM for a time like 1/4 mile or slalom racing or someting similar, then 35 to 40 would be fine.
I run a mellings High volume/ high pressure pump but have 7 usable quarts in a Milodon pan. The higher the volume the pump, the more oil you may have up in your valve covers and not in the pan. I also use Mobil1 20w50 for the phospor and zinc. My pressure is 30 to 35 at idle when hot and 70 when cruising, but again it is due to the pump and viscosity i run.
Old Jun 28, 2019 | 09:14 AM
Richard Blanchard
8th Gear
Default oil pressure
Thanks for impute guys. After taking my oil pump apart I found the slide piston stuck open the spring is suppose to control. I freed it up and put in a new purple spring. Mine is a Melling M55-HV pump as well.
Old Jun 28, 2019 | 09:23 AM
gkull's Avatar
gkull
When using HV pumps you need to put some thought into larger volume pan, limiting oil restrictors to the top end, and block off the oil filter bypass
Old Jun 28, 2019 | 11:25 AM
HeadsU.P.'s Avatar
HeadsU.P.
Not trying to steal your thread Richard, but I have the Melling 55HV with the purple spring as well plus extra Qt pan, and would like to hear more about the filter by-pass.
Previous posts said you should never do this. Others say its ok.
What could go wrong? Right?
Also, a excellent video on YouTube by a pretty sharp hot rodder says its impossible for a Melling High Volume pump to empty a oil pan. He said its an old myth. Just not going to happen. The pickup tube is not capable of moving that many quarts per minute.
I will say that with some aluminum heads, the drain-back holes at each end of the head are, well, a little disappointing. Mine has a puddle there every time I pull the valve cover. Looks like a lot of oil standing, but likely is only a tablespoon.
Old Jun 28, 2019 | 11:37 AM
Kacyc3's Avatar
Kacyc3
either way you could end up with engine failure, your choice to decide allowing the metal in the oil to bypass the filter and reach the bearings or risk starving the bearings for oil while it is being pumped through the filter.
Old Jun 28, 2019 | 01:57 PM
gkull's Avatar
gkull
So I don't have to figure out the pictures again. I posted picture of the bypass under the filler plugged and sealant around it to hold it in. If your oil pressure exceeds the pump spring check valve the oil is then bypassing the filter and getting pumped back into the oil pan. Kind of a waste of energy, but you won't burst your cheap oil filter canister. If you have a motor exceeding 5500 rpm and you really do want to have the 10 psi per 1000 rpm then the bypass plugged is the answer. If you want 30 psi at hot idle to make your roller lifters last then you need a higher volume pump and oil viscosity high enough weight to maintain those pressures.
It is not just the total flow of the pump tube that can be the problem. what if you are hauling a$$ on a long freeway on or off ramp and the "G" forces move what little oil is left in the pan over away from the pickup? I used to get a flickering oil pump light going around turns with a 8 quart road racing pan.
https://www.corvetteforum.com/forums...-together.html
Old Jun 28, 2019 | 07:34 PM
derekderek's Avatar
derekderek
that piston stuck open once. please spend 60 bucks on a new pump. an old used one would be better. at least it's piston fits the bore.
Old Jun 28, 2019 | 07:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
no need to on most st engines, as said a high rpm I always plug it; a std volume Z28 spring is good enough also
Just use a good quality oil filter and let the oil get good and hot before leaning on it.
Youll know when your idle oil pressure drops significantly from cold.
To Proper oil pressure for C3
