new oil line from vendor came with a new fitting?
(1971 w/350) getting ready to put new gauge bezel in and decided that before that best order new oil line. Did so and I believe it is from Corvette America. It came and I was going to get started today but noticed a new fitting in bag with line. Is this fitting for in the block ? (diff from original there now) - I don't see how it could work on back of gauge so assume must be for block? I do know new line will screw on better to the new fitting verses old one on block. Old one has bigger hole in center for oil flow also but I imagine that don't matter. Any input on where it goes?
Dementer sole survivor
Received 6,295 Likes
2016 C3 of Year Finalist
pics???
sorry- I can't do pics yet.. just getting around on pc. I can say fitting screws into block as original but is slightly shorter and oil flow smaller hole. but new line screws into it better than old fitting
try it and watch for leaks
I ordered one for my 68 and it also came with a new fitting for the the block and yes it was the same. I changed mine. You probably do not need to change it. The new hose should fit and seal fine.
