Unknown MasterCylinder on my vette
Old Jun 19, 2019 | 04:03 PM
phminell's Avatar
phminell
Default Unknown MasterCylinder on my vette
Hello,
I have a 1977 vette, but with very few stock parts...
I need to change my Mastercylinder which is leaking in the Mastervac.
I checked the outputs and I have 2 identical 9/16" outputs, which is unusual for a 1977 vette that has normaly a 1/2" and a 9/16" output.
Do you know what type of MasterCylinder I have ?? camaro ? anything else ?
Thanks !
Old Jun 19, 2019 | 04:07 PM
Kacyc3's Avatar
Kacyc3
Originally Posted by phminell
Hello,
Thanks !
post a picture.
Old Jun 19, 2019 | 04:16 PM
phminell's Avatar
phminell
Here you go
Old Jun 19, 2019 | 04:17 PM
Kacyc3's Avatar
Kacyc3
looks like a stock one to me.
Old Jun 19, 2019 | 04:22 PM
phminell's Avatar
phminell
Looks like but is not : the ports are both 9/16"...
I just bought a new mastercylinder which I cannot mount because it has a 1/2" front port and a 9/16" rear port
Old Jun 19, 2019 | 04:26 PM
Kacyc3's Avatar
Kacyc3
maybe the new master cylinder is wrong.
Old Jun 19, 2019 | 05:32 PM
bmotojoe's Avatar
bmotojoe
Just checked a new Bendix Master 11749 for my 77. The front port is smaller vs. the rear. Have no idea what you have. May need to remove and match.
Old Jun 19, 2019 | 07:21 PM
HeadsU.P.'s Avatar
HeadsU.P.
I bet that over the course of several years somebody changed one of the brake lines to the MC or changed the fitting itself. I have a '77 and yes, you should have two different size ports / fittings.
Old Jun 20, 2019 | 02:45 AM
davidbii's Avatar
davidbii
I’ve got the same deal on my 73. At some point it was swapped. There should a stamped/embossed code on it. Google that number and you’ll find the correct one. Mine ending up being from a mid 70’s 3/4 ton truck if I remember. It also used a different length rod to press on the piston. So, find that code
Old Jun 20, 2019 | 02:58 AM
phminell's Avatar
phminell
OK Guys, thank you for your help ! I found the solution :-)
I was mistaken by the fitting itself :
I checked with a slide gauge : both fittings go with 9/16" wrench, but one is 1/2" thread and the other a 9/16" thread.
Sorry for the disturb :-(
To Unknown MasterCylinder on my vette
