Vortec Headers?
Old Jul 7, 2019 | 03:54 PM
eddp's Avatar
eddp
Default Vortec Headers?
I'm reading the "small print" about the BluePrint engine I want to put in my '81. The aluminum heads say they are "similar to vortec cast iron heads." They have raised exhaust ports and are .500" higher than the vortec. They suggest that because of the raised exhaust ports, header clearance may be an issue and to use a header designed for the vortec heads that route the pipes up high.
Has anyone dealt with this and/or have header recommendations?
Old Jul 7, 2019 | 05:56 PM
gjohnson's Avatar
gjohnson
Where did you read this fine print?
Old Jul 7, 2019 | 06:12 PM
eddp's Avatar
eddp
Default Blueprint Heads
It was in the info provided by BluePrint about the heads.
Old Jul 8, 2019 | 08:15 AM
Kacyc3's Avatar
Kacyc3
I reused stock manifolds on the truck i had when I did the vortec swap and with my fastburns I used 1.75 primary headers.
Old Jul 8, 2019 | 10:08 AM
gkull's Avatar
gkull
Heads like Dart and AFR have .600 raised exhaust ports. Not a big deal because of the v angle. It becomes something like. 300 up and. 300 outboard.
Old Jul 8, 2019 | 10:24 AM
derekderek's Avatar
derekderek
and it is not Vortec. it is raised ports. 1st gen thru vortec all used same exhaust port config until aftermarket decided this is a better exhaust port angle. they are right, but sometimes engine compartments disagree.
Old Jul 9, 2019 | 07:11 AM
cooper9811's Avatar
cooper9811
Exhaust ports raised .500 and .600 sounds really high. Last time I looked at AFRs website (which was just in the last couple weeks) the most I saw was .250 (which is what I have with my AFR 210s,and with 195s I used in the past.) Is this new or not a small block?
Old Jul 9, 2019 | 06:04 PM
Scott Liggett's Avatar
Scott Liggett
The exhaust ports on BluePrint's H8002K small block heads are raised .300". The spark plugs are also configured into the chambers like Vortecs because the heads have a Vortec type heart shaped combustion chambers. The two center plugs are 1/2" closer together than the 1970's era 882 type factory heads.
I believe many guys here on the forum with BluePrint's engines that include those heads are using standard sbc Hooker headers for C3 Vettes without a problem. I am sure someone here could get the part number for you.
If you want to run shorty or block hugger headers, use ones designed for angle plug heads. They keep the pipes away from all the spark plugs. Speedway Motors has a set that BluePrint has tested and worked great.
Old Jul 10, 2019 | 07:19 AM
derekderek's Avatar
derekderek
new guy. 4 posts. and you know what you are talking about. welcome aboard. many newbies here ask stupid questions, not give intelligent answers...
Old Jul 11, 2019 | 09:37 PM
jackson's Avatar
jackson
Default Here's a bit of Help figuring raised-port headers' position in bay
HS trig
sbc & BBC are 90* motors ... cylinder banks are 45* from X axis (and Y) ... use sine of 45* = 0.707xxxxxxxxxxxxxxxxxxx
if ports are raised 0.300" ... then sin45* x 0.3" = 0.212xxxx" = in relationship to crank, ports are moved UP (y) AND moved Outboard (x) some 0.212"
if ports are raised 0.500" ... then sin45* x 0.5" = 0.354xxxx" = in relationship to crank, ports are moved UP (y) AND moved Outboard (x) some 0.354"
if ports are raised 0.600" ... then sin45* x 0.6" = 0.424xxxx" = in relationship to crank, ports are moved UP (y) AND moved Outboard (x) some 0.424"
another example but with an additional calc ... 60 degree motors require a little different trig.
Chevy also made several 60* V6 motors (60* between banks & from X) such as iron head & block pushrod V6 2.8L in early S10 pickups etc.
As the cylinder banks move closer to Y axis, raised ports move proportionally (than 90* motor) Farther UP BUT proportionally Less Outboard.
Banks are 30* from Y axis and 60* from X axis.
60* motor: sine of 60* = 0.866xxxx" AND cosine of 60* = 0.5"
if ports are raised 0.300" ... then sin60* x 0.3" = 0.259xxxx" AND cos60* x .3" = 0.150" ...
... in relationship to crank, ports are moved UP (y) some 0.260" AND moved Outboard (x) 0.150"
perhaps above might help some to pre-determine exhaust clearance
To Vortec Headers?
