Ls swap oil pans
Old Jul 18, 2019 | 05:54 PM
ayellow56's Avatar
ayellow56
Cruising
Default Ls swap oil pans
Well it's time to retire the Gen 1 sbc in favor of a built LQ 9. For those who have done this what oil pan have you used.? I have a Batwing from a 04 ZO 6 that was a gift. I am just finishing the long block buidup so all options are out there. The truck pan is way too low to even consider at this point.It will have a TKO 600 etc on the backside and a re-geared diff.
Old Jul 18, 2019 | 08:44 PM
Gordonm's Avatar
Gordonm
I am using a stock 09 LS3 pan from a Corvette
Old Jul 19, 2019 | 12:21 AM
bluegtp's Avatar
bluegtp
Fbody pan on my ls3 here.
Old Jul 19, 2019 | 01:42 PM
supervette64's Avatar
supervette64
Fbody pan on my LS3 as well. Fits great. Essentially the same envelope as the stock SBC pan.I think the batwing would fit though... mmmaybe headers wouldn't clear but I don't think so.
Old Jul 19, 2019 | 02:26 PM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
Batwing
Old Jul 19, 2019 | 03:23 PM
Corey_68's Avatar
Corey_68
LS F-body oil pan here
Old Jul 19, 2019 | 05:06 PM
ayellow56's Avatar
ayellow56
Cruising
Did you fab your own headers or did a production set fit? Also I'm set up for mechanical clutch linkage with a Quik Time bellhousing.
Old Jul 19, 2019 | 05:21 PM
ignatz's Avatar
ignatz
ARH headers and mechanical clutch are incompatible.
Old Jul 19, 2019 | 06:12 PM
ayellow56's Avatar
ayellow56
Cruising
Well , since the chassis and body are separated IT.S BREAK OUT THE TIG welder and start fabbing up some 304ss headers. I'll probably be using Magnaflow.s builders kit. This is not the first time I've had to custom build a set. Thanks guys for your input . Steve.
Old Jul 19, 2019 | 09:42 PM
bazza77's Avatar
bazza77
https://ls1tech.com/forums/conversio...-oil-pans.html
Old Jul 25, 2019 | 02:42 PM
70 LS1's Avatar
70 LS1
F-body pan
Old Jul 26, 2019 | 09:21 AM
Denpo's Avatar
Denpo
Stock LS exhaust manifold too.
I went with the batwing.
Old Jul 26, 2019 | 06:07 PM
Garys 68's Avatar
Garys 68
02 Batwing with the 02 vette exhaust m manifolds. I think the batwing limits your exhaust manifold selection, but the 02 manifolds flow very well, fit the vette frame and allow for z bar attachment.
Old Jul 27, 2019 | 02:07 AM
Denpo's Avatar
Denpo
Really? I went with the batwing and the "LS6" stock manifold and the manifold is all in the way. Could it be that it's because my LS is all the way backward to accomodate the T5 (T56/LS combo seat further to the front). I any case I'd love learn where is got my math wrong, I miss the mechanical linkage.
Old Jul 27, 2019 | 01:15 PM
Garys 68's Avatar
Garys 68
See post 6 here:
https://ls1tech.com/forums/conversio...-ls-motor.html
That was with 1" setback plates, I ended up moving the engine forward using the standard adapter plates. Plenty of room for the Z bar between the manifold and O2 sensor.
Old Jul 27, 2019 | 02:19 PM
ignatz's Avatar
ignatz
The LS3 crate motor in the stock position drops right in, and with a little bit of finagling, the mechanical clutch linkage can also be accommodated.
up.
To Ls swap oil pans
