Output rod from hydro boost to mc
Old Jul 19, 2019 | 03:45 PM
atthemattin's Avatar
atthemattin
Default Output rod from hydro boost to mc
So I just figured out my brakes aren't engaging because the output pushrod from my hydroboost is roughly 1/2 too short. The rod is just about 3.20in long. I guess my question is, has anyone else delt with this? Are there adjustable pushrods? Do I make a spacer? Or is it better to make a different rod? I'm running an astro van booster with a will wood 1 1/8 master
Old Jul 19, 2019 | 03:49 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I ended up making a spacer. I had a piece of aluminum that was the right diameter and just drilled the input end to accept the pushrod from the hydro boost unit. Worked perfectly. Was more than 1/2 inch long though.
Old Jul 19, 2019 | 03:51 PM
atthemattin
What side did you put the spacer in? The Mc or hydroboost side?
Old Jul 19, 2019 | 07:47 PM
'75's Avatar
'75
Put it in the master cylinder, I've done it before, works good.
Old Jul 19, 2019 | 08:06 PM
CA-Legal-Vette
To Output rod from hydro boost to mc
