ECM Delete
Old Jul 20, 2019 | 12:07 PM
eddp's Avatar
eddp
Default ECM Delete
Ed's topic/questions of the day.
As I'm reading the shop manual about the Computer and what it monitors and controls, I notice that the neutral safety appears to give input. I know the ECM also controls the converter lock up.
When disconnecting all the sensors, etc..., will I get a check engine light? If I disconnect the connectors to/on the ECM, will that prevent the check engine light from coming/staying on? I'm assuming that when I pull the connectors to the ECM, one wire in the plug is power to the ECM.
As I understand it, the trans will work fine, but will not lock up at higher speeds, resulting in some mpg loss. I've been told by the local trans shop that they can fix the trans to hydraulically lock up.
Can those who have deleted the ECM please share your experience and suggestions, especially about the affect on the neutral safety (if any) the check engine light, and pulling the plugs off the ECM? TIA!
Old Jul 20, 2019 | 12:30 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I’m not certain if you CEL will come on if the computer is removed. I suspect not. Easy to check though, just unplug it.
If you remove the computer, losing lockup is the least of your concerns. You’ll have to replace the distributor or you won’t get any advance. You’ll also have to replace the carb. Both are controlled by the CCC.
Old Jul 20, 2019 | 12:44 PM
eddp's Avatar
eddp
I know that I must replace the dist and computer. Still trying to get that aspect straight. Originally planned on an Edelbrock 1406 carb on an Edelbrock 2101 intake and an HEI dist. Edelbrock tech says that a 2701 intake won't fit under corvette hood, yet many on other forums say they have it and it works fine?? Now, looking at using stock intake and putting a Holley 4175, which is advertised as a Qjet replacement. I'm not looking for much, if any, of a boost in hp, but want to find one that fits under the hood. I'm getting a ton of conflicting advice about set ups. Which intake, carb, and air cleaner combination will fit under a stock '81 hood?
Old Jul 20, 2019 | 07:13 PM
wilcar's Avatar
wilcar
Friend used the 2101 intake and 1405 carb on his 81 with a 2" tall air cleaner and everything clears fine.
Old Jul 22, 2019 | 09:22 AM
Kacyc3's Avatar
Kacyc3
The ecm does control lock up, so you will need to move that to a manual switch or a vacuum switch from Summit you can install this yourself and is adjustable to your liking.
The Ecm may control timing, it is possibly you may need a different dist.
The ecm definitely used the carb for input removing ecm may affect the way it runs.. Replace carb.
intake manifold may or may not have provision for choke and require a quadrajet replacement. New intake will resolve the coke issue and may also be needed for new carb pattern.
unplugging the ecm should stop any ecm related CEL.
lock up is required on the 700r4. When in over drive the pump stops pumping the fluid to make the engine more efficient, allowing the convertor to slip causes heat and has no way to dissipate the heat resulting in a burnt up trans.
Old Jul 22, 2019 | 10:21 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
It would be a TH350 w/lockup if it has a CCC carb.........700r4 was 82 only......but the song remains the same.......it will run ok but generate a lot of heat and fuel mileage suffers badly......
Jebby
Old Jul 22, 2019 | 11:04 AM
Kacyc3's Avatar
Kacyc3
Jebby
I forgot about that being an option on the th350.
Old Jul 22, 2019 | 06:31 PM
derekderek's Avatar
derekderek
could lockup be done with a switch? maybe vacuum or TV activated?
Old Jul 22, 2019 | 08:14 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
TCI and B&M have lockup switch kits that mount the switch to the carb I believe.....
I wired a toggle on my 82’ CrossFire Camaro when I deleted the CFI.....it worked great but you HAVE to make sure you shut it off before you get off the highway and stop or it will shudder...and stall the engine...
Jebby
Old Jul 23, 2019 | 09:32 AM
Kacyc3's Avatar
Kacyc3
Jebby
I wired mine in to the cruise control circuit for the power source of the trigger wire. This will interrupt power to the trigger anytime the brakes are applied avoiding the shuddering you mentioned if forgotten or in a panic stop.
Old Jul 23, 2019 | 09:49 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Great idea and I have heard of that....
Jebby
Old Jul 30, 2019 | 09:50 PM
Puniphorous's Avatar
Puniphorous
Sorry to butt into a thread...
I have eliminated my computer on my '81 with a new distributor and carb too.
Would you care to elaborate on the process of wiring into the cruise circuit? Diagrams? Links? I have searched, but my search-fu is lacking.
Thanks in advance!
I will start a new thread for this if that is prudent and polite.
Old Jul 31, 2019 | 12:31 PM
Kacyc3's Avatar
Kacyc3
Thanks in advance!
you must have a brake switch for a car with cruise control
locate the terminal on the cruise side of the switch that loses power when brakes are applied. (this is your power source for trigger wire) wire to lock up plug.
route ground of trigger wire to manual switch, then ground manual switch
run ignition hot fused + 12v power to lock up connector
route - 12v ground from lock up connector to ground.
Old Jul 31, 2019 | 10:11 PM
Puniphorous
Thanks!
To ECM Delete
