1980 Corvette A/C Question
Old Jul 23, 2019 | 06:39 AM
doning's Avatar
doning
Default 1980 Corvette A/C Question
Hello everyone! I have owned my 1980 Corvette for about five years now. Strange enough to say, I never used the A/C in the car. I am not sure if the woman I bought it from used it either. If it's hot, I don't drive it. I want to try the A/C. I'm sure it don't blow cold anymore but I want to see. My question is, is there anything I should check and/or inspect before flipping the switch? I'm nervous something is going to go wrong.
Thanks again!
Don
Old Jul 23, 2019 | 09:38 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I'd put the air on and give it a try. If the system has pressure you'll hear the clutch engage on the front of the compressor. If the system doesn't then the clutch will not engage... you'll hear a click when you do this. There is nothing to hurt by dong this in my opinion. If there isn't enough pressure and you want to test the compressor you can jumper the pressure switch to see if the clutch engages.
Willcox
Old Jul 23, 2019 | 03:54 PM
SwampeastMike's Avatar
SwampeastMike
Do be ready to turn it off very quickly if you hear squealing or the idle drops drastically--both these can mean a locked rotor. A locked rotor will ruin the belt very quickly.
Old Jul 23, 2019 | 05:59 PM
interpon's Avatar
interpon
Make sure belt is very snug first,, dont ask me how i know
Old Jul 23, 2019 | 10:04 PM
vince vette 2's Avatar
vince vette 2
But not too snug ... don't ask me how I know
Old Jul 24, 2019 | 06:36 AM
doning's Avatar
doning
Okay Guys! The next time I take her out I will give it a try!
Old Jul 24, 2019 | 09:43 AM
vince vette 2
Good luck. I've had my 1980 since new. Spent the first 2 years with it in TX. Then moved back to NY for a year in Stafford, where I grew up. It's next to Batavia, so the same climate as Palmyra (that's a NY plate on the car in my avatar and the yellow color dates it). Then moved to PA near Harrisburg. The A/C started leaking by the time the car was 4 years old. I suspect that is typical. I drove the car regularly until about 1986. After that it was just for fun until about 2004. Basically from '86 to '04 the A/C was empty and thus unused - hey windows down, tops off - we don't need no stinkin' A/C. Growing up in the 60's in western NY, none of our family cars had A/C until my mother bought a new LeSabre in '74.
Despite the lack of A/C and many years of non use, the compressor is not seized. So regardless of the Freon status, there's a good chance it's functional. But given the 5 years you've had, it's unlikely to have a Freon charge unless it was rebuilt somewhere along the way. And if rebuilt a question would be if it was updated to run on the new Freon.
Old Jul 24, 2019 | 01:59 PM
doning's Avatar
doning
Yes, I highly doubt it blows cold. The car is all original and never had the upgrade done. Can you purchase the old Freon?
Old Jul 24, 2019 | 03:04 PM
vince vette 2
I'm not sure of the law on that. But if you check the c3 parts for sale you might find a recent offer.
Old Jul 24, 2019 | 04:20 PM
interpon's Avatar
interpon
Ebay and craigs list
you will pay anywhere from 18 to 40 bucks for a 14 ounce can..takes three cans min if empty. See specs but should hold 3 pounds r12.
Try it see if compressor comes on..if not AND if you push schrader valve does anything come out? If so i would get gauges ( get them anyway) see what pressure is in and try a can ( assuming r12 still if you know history)
if empty...consider using shop air pressurize check for leaks holding pressure. If it does check orifice for metal or other issues...if ok
no leaks change orifice, accumulator..pull vacuum add r12? Or consider flushing, remove and manually empty compressor oil and convert oil and go r134a
again make sure belt is adjusted ok..squalling compressor may be loose belt not necessarily failing compressor...
good luck, report back
Old Jul 24, 2019 | 05:05 PM
SwampeastMike
Yes, you can get R-12. Expensive but not ridiculously so. Full system charge is three pounds.
If it's not working you MUST find the problem(s) before throwing in some refrigerant! In the even that the compressor is seized and you intend to keep the R-12 system buy the DELCO "professional" unit only! Ask me how I know... The accumulator which is always suggested to be replace in an old system that has stopped working is hideous to replace--utterly requiring a 1 1/8" crow's foot wrench (very hard to find and expensive) unimaginable (to me) without a lift.
The above said you're still better off with the R-12 system as long as the condenser ahead of the radiator does not leak because an "update" to a more modern compressor and/or refrigerant requires that the condenser be replaced for the system operate properly. You'll also loose the highly refrigerated air you get from the original R-12 system.
Old Jul 24, 2019 | 05:11 PM
interpon's Avatar
interpon
I cut old one to lower accumulator
new one is two piece and may need heat bend
get the new channel lock wideazz short wrench
it works
https://www.menards.com/main/tools/h...363517&ipos=15
my compressor working ok this week..said professional on the box lifetime warranty if proof of getting orifice and accumulator
https://www.napaonline.com/en/p/TEM2...put=compressor
To 1980 Corvette A/C Question
