Master cylinder plug size
Old Jul 23, 2019 | 05:02 PM
Runningwild's Avatar
Runningwild
Default Master cylinder plug size
I’ve bleed the new MC and want to plug it while I install new lines and brakes. What is the bolt size to plug the master cylinder
thanks. Tom
Old Jul 23, 2019 | 06:58 PM
HeadsU.P.'s Avatar
HeadsU.P.
STOP! Do Not insert a bolt in that port. You could damage the flare inside and the brake line may never seal.
Go to your favorite car parts store and buy a ready-made brake line with the correct brass fitting on the end. You can find them as short as a foot or less. Then bend the line to pinch it off. You will use that piece of line over & over to test the MC.
I do not recall the dia or tpi of the fittings but the rear is different than the front.
Old Jul 23, 2019 | 08:18 PM
Peterbuilt's Avatar
Peterbuilt
Advance auto has Master cylinder bleed kits in the help section.
It has the (plastic) plugs you need.
Old Jul 24, 2019 | 09:52 AM
c3_dk's Avatar
c3_dk
To Master cylinder plug size
