Need c3 guru advice
Old Jul 26, 2019 | 06:18 AM
hardhattg's Avatar
hardhattg
ZR1TG
Default Need c3 guru advice
Have 69 all original 300hp automatic with factory air very original Ncrs type car
2 questions
1. What is best oil pan gasket to use to prevent leaks. Paid a shop to replace rear seal and oil pan gasket and they did a horrible job . I will look to redo it myself this weekend. Should I use a one piece gasket ?
2. The car is in south florida and in the heat of the afternoon it runs too hot with ac on ( just when you need it ) especially when extended idling occurs . I don’t want to radically change it , don’t want to put modern ac compressor or modern radiator if I can help it. Was wondering if anyone knows if the gm shroud extender would substantially help and if I should switch to a seven blade flex fan maybe ? And if so any recommendations for something sort of original looking and a direct fit ?
Greatly appreciate all advice.
Old Jul 26, 2019 | 06:52 AM
The Punisher's Avatar
The Punisher
For your first question. I would take it back to the shop and tell them to fix it right
Old Jul 26, 2019 | 07:30 AM
hardhattg's Avatar
hardhattg
ZR1TG
No thats out. As much as I don’t look forward to being under the car most of the weekend I will never bring it back there , that was a major mistake.
Old Jul 26, 2019 | 08:02 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
FelPro makes a very nice, one piece, with steel grommets in place (to prevent over tightening), oil pan gasket. I do know that GM used two different thicknesses of "end seals" for the oil pan, based on model years. I don't know however, what the "break point" was, with respect to the model years. I also am unsure if FelPro offers this particular pan gasket with both of the end seal thicknesses, or just the later years. I used this particular gasket on a 90s SBC, with good results.
Old Jul 26, 2019 | 09:05 AM
VERYSOON's Avatar
VERYSOON
Hardhat
I have the same engine, original fan and factory ac and runs cool all the time. I bet your radiator just needs to have 50 years of sludge boiled out of it by a radiator shop! Also, upon getting the timing right, as per Lars instruction, I found the car to run cooler (and quicker, initial advance at 12 degrees.)
VS
Old Jul 26, 2019 | 11:35 AM
eff10mm's Avatar
eff10mm
2 questions
I just got done with my rear main seal, so it's still fresh in my mind. It really isn't hard to do, but it takes longer than you think it would. I used a FelPro 2912 rear main seal and the OS 3510T oil pan gasket. The Felpro snap ups work great when you're trying to get the pan on by yourself from underneath. The snap ups come with the oil pan gasket as well as all new bolts. You put just a little RTV in the corners as per the gasket instructions. I have no leaks now on my Vette and that makes me very happy.
Old Jul 26, 2019 | 02:18 PM
hardhattg's Avatar
hardhattg
ZR1TG
Originally Posted by VERYSOON
Hardhat
VS
Verysoon
are you also also located south florida ? This car runs cool all the time as well except in peak heat of afternoon when sitting at idle for a while like at a long light , is not a problem in winter here which is maybe eighties during the day. Just summer.
Old Jul 26, 2019 | 02:43 PM
Greg's Avatar
Greg
Just another Corvette guy
Technology has moved way beyond old cork gaskets. Use the Felpro one piece, you won't be sorry. It's the only oil pan gasket I'll use now.
Old Jul 26, 2019 | 04:26 PM
theandies's Avatar
theandies
When you have your pan off take a straight edge and make sure your sealing surfaces are flat. If not gently tap them flat with a small hammer. Check again, rinse and repeat until nice and flat. I'll bet you'll find its dimpled at every bolt hole.
Old Jul 26, 2019 | 08:23 PM
derekderek's Avatar
derekderek
And keep in mind. You bend metal then bend it back, it is softer and easier to bend back the other way. Take care not to overtighten oil pan bolts. Temps. Check seals around radiator. Maybe a little home depot stick on foam in any obvious gaps. But verify your temps. It might be 190-200 and telling you 230. Gauge and sending unit ain't young. And if one is they may not be fully compatable.
Old Jul 27, 2019 | 03:46 PM
hardhattg's Avatar
hardhattg
ZR1TG
Thanks everybody good advice as always.
Anyone have Have any experience with gm shroud extender ? Or a seven blade
flex fan vs the stock clutch fan I have which is oem ?
Old Jul 27, 2019 | 06:17 PM
MelWff's Avatar
MelWff
Stick with the factory fan using a clutch. You are sure the clutch works correctly and you are not missing any of the seals around the radiator.
Old Jul 28, 2019 | 12:10 AM
jpatrick62's Avatar
jpatrick62
Hardhat
VS
I was thinking the same thing. At 50 years the original radiator just isn't what it used to be. If need be, maybe turn to a 4 core aluminum radiator which should work just fine.
To Need c3 guru advice
