Intake help + gasgacinch?
Old Jul 29, 2019 | 06:09 PM
Novusuhu's Avatar
Novusuhu
Default Intake help + gasgacinch?
Hey everyone
It's my last week in the US now...
I have two questions regarding products for my 77 l48.
1. I've looked in the Summit Georgia store, and multiple Advanced auto parts and Autozone stores, but they all didn't have Gasgacinch...
Is there an alternative product for 'gasgacinch' to use with the intake manifold gaskets?
2. I will use the Edelbrock 7201 gasket that came with my performer intake. I read some reviews on the gasket and it seems to be a good gasket.
I will keep the heat stove choke. Do I need to use the crossover block off plates (they don't intirely block off the two crossover ports, because there is a hole in the plates).
Use the plates or not?
Don't have the EGR provisions on the new intake, and I'm running headers, so no EFE either.
Old Jul 29, 2019 | 06:18 PM
jim2527's Avatar
jim2527
Permatex Indian Head?
Old Jul 29, 2019 | 06:19 PM
derekderek's Avatar
derekderek
never heard of it before just now. the can implies it is similar to Indian Head gasket shellac compound. we all use silicone RTV. but go to their website and click where to buy. http://gasgacinch.com/ girl on the can on her back with legs in the air. maybe it is good for other stuff besides gaskets...
Old Jul 29, 2019 | 06:32 PM
suprspooky's Avatar
suprspooky
I have used Permatex High Tack successfully several times over the years instead of the Edelbrock product.
The heat riser passage will slightly hurt performance if not blocked off, I dont think it's going to be noticable on a street only car though imo. If your manifold/carb have a divorced choke setup the choke spring will take longer to relax if heat riser/passages aren't operational.
That whole design is an emissions control system, my BB AFR heads don't even have the passages and yet my divorced choke on the tri-power manifold works fine (choke pull off works harder till the spring relaxes).
Old Jul 29, 2019 | 08:28 PM
HeadsU.P.'s Avatar
HeadsU.P.
Permatex, The Right Stuff.
Except around the water ports. I prefer Permatex clear RTV there.
Summit sells that Gasgacinch, but I did not see it on the shelf in GA Summit either. Have to ask at the parts counter. It is an exclusive Edelbrock product and may not be ordered by companies like Advanced or the Zone. It works really well, except at the water ports.
Keep in mind the intake gasket has to seal not only gasoline, but oil and anti-freeze.
Old Jul 29, 2019 | 09:19 PM
cv67's Avatar
cv67
St. Jude Donor '05
I use the brown permatex brush on stuff. Goes great with the cork gaskets on the china walls.If you let it set up and use a dab of right stuff in the corners youll be happy
Silicone shrinks over time
8 yrs no leaks yet albeit lo miles.
Old Jul 29, 2019 | 09:45 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Another believer in "High Tack" here....been using it on intake gaskets for 40 years. I would also suggest procuring another set of gaskets. Never hurts to have a spare set...just in case!
Old Jul 29, 2019 | 10:45 PM
Novusuhu's Avatar
Novusuhu
Ok, guys thanks for the info!
I just read some other reviews that the edelbrock gaskets 2701 are designed to go with edelbrock aluminum heads... they won't fit my stock l48 heads.
I will go for Fel-pro, but there are two sets that the Summit filter offers:
With block plate?
Felpro MS90322
https://www.summitracing.com/parts/f...SABEgJCDvD_BwE
Felpro 1204
https://www.summitracing.com/parts/f...SABEgLfovD_BwE
Without block plate?
Felpro 1256
https://www.summitracing.com/parts/f...make/chevrolet
Old Aug 2, 2019 | 07:43 PM
Novusuhu's Avatar
Novusuhu
What do you guys think?
Will the blocked off crossover do any harm to my engines performence? Will it do any harm on long therm?
I will keep the 'heat stove choke'. Will choke still work good, when the crossover is blocked?
Already done:
- EFE system is completely removed.
- EGR system is completely removed.
- A.I.R. system is removed.
- Longtube headers installed and true dual exhaust
Old Aug 3, 2019 | 01:17 PM
KJL's Avatar
KJL
I do not like Gasgacinch. I only use RTV around water ports and on the china walls. When that stuff gets hots it weeps from all the joints where it is used. Makes quite a mess. It is probably OK using small dabs to locate and hold the gasket in place but I would not use it for sealing. It seems like it never completely cures. It is basically contact cement.
Old Aug 3, 2019 | 05:58 PM
HeadsU.P.'s Avatar
HeadsU.P.
I never had any issues with Gasgacinch. You would think that whatever the world leader in Intake Manifold design and number one in sales recommends has more credibility than someone here on this forum.
You have to give that product time to set up overnite. It is not a "quick-set" like The Permatex Right Stuff is. That product was designed for mechanics / shops that need quick turn-around time and get the customer out-the-door.
You be the judge.
Old Aug 3, 2019 | 07:11 PM
Novusuhu's Avatar
Novusuhu
You be the judge.
Old Aug 3, 2019 | 07:16 PM
OldCarBum's Avatar
OldCarBum
I've used Gasgacinch for years and as stated above it is not a hurry up and get it together product.
If you use it as directed it is great stuff.
It will last you a long time as it takes just a smear on each surface.
Less is better.
If you gob it on like RTV it will be a mess.
A good RTV works well, just read all the labels and use as the manufacturer directs.
Old Aug 5, 2019 | 01:14 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If you run the crossover blocked....the choke may not function correctly. You would have to convert it to an electronic choke. Blocking the crossover does nothing to hurt and in fact helps the engine live longer by keeping the heads and intake cooler. Hot heads mean thin oil. Any modern small block build does not even have provision for it and very few aftermarket manufactures offer a head with it. Block it, convert to electric choke and be happy
Jebby
Old Aug 5, 2019 | 08:03 PM
Novusuhu's Avatar
Novusuhu
Jebby
I would like to go with a manual choke... If that is possible and not much work?
Old Aug 6, 2019 | 11:22 AM
OldCarBum's Avatar
OldCarBum
The choke on my 73 hasn't worked since I purchased it.
I just start it up first thing in the morning and keep the rpm up to about 1100 until it will idle on its own.
As soon as the temp gauge starts to move it is time to go and it starts and idles the rest of the day without any issues.
Not having a choke is no big deal especially when some of us old guys grew up running cars without them.
I never had a choke on any of my drag boats and on my Malibu and Mastercraft ski boats, I pulled the choke as they would always load up first thing in the morning for those 05:30 a.m. ski runs.
Old Aug 8, 2019 | 04:20 AM
Novusuhu's Avatar
Novusuhu
Jebby
Do I have to apply sealant around the crossover port also? I can imagine that it will get very hot around that 'exhaust' port.
Or are the metal blocking plates enough?
To Intake help + gasgacinch?
Old Aug 8, 2019 | 05:40 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No.....just around the backside of the four coolant outlets in the corners.
Jebby
Old Aug 8, 2019 | 09:44 AM
C3_DH's Avatar
C3_DH
I've always thought the girl in a dress with her legs in the air was "value added".... LOL. Seriously, I've used Gasgacinch on my Edelbrock intakes for years with no issues whatsoever.
Old Aug 8, 2019 | 10:02 AM
BLUE1972's Avatar
BLUE1972
