Key in steering column clicks
Old Jul 31, 2019 | 12:08 AM
70s Vette Guy's Avatar
70s Vette Guy
Default Key in steering column clicks
I have a 72 column that when I turn the key it clicks or grinds and sends no power to the starter. I assume it needs a new rack kit or ignition activator hardware, but never done this job and would appreciate any comments.
Jim
Old Jul 31, 2019 | 12:37 AM
bazza77's Avatar
bazza77
Tilt column ?
Do you get accessories power ?
headlights can work ?
Old Jul 31, 2019 | 01:17 AM
GunPowder's Avatar
GunPowder
Where does the "click" come from? Turning the key itself should not make a (significant) clicking sound. So you might have power at the starter (e.g. when the click comes from the starter solenoid).
Old Jul 31, 2019 | 01:25 AM
70s Vette Guy
Yes it is a tilt/tele. When I turn the key, nothing electrical works. The click/grind comes from the key turning, sounds like something is stripped. It is not a starter click.
Jim
Old Jul 31, 2019 | 01:35 AM
bazza77's Avatar
bazza77
http://jimshea.corvettefaq.com/?cat=5
GunPowder's Avatar
GunPowder
Switch or rod operating the switch could be faulty or just misaligned / loose.
Do you know Jim's steering papers?
Old Jul 31, 2019 | 01:40 AM
bazza77's Avatar
bazza77
https://www.restore-an-old-car.com/c...mn-repair.html
Not sure that's your problem but it is interesting to see anyway.
Old Jul 31, 2019 | 02:12 AM
70s Vette Guy
I have read a few of Jim's Papers and once I know what parts have gone bad, I'm sure they will be of assistance. I was hoping to find someone that has had the same problem to help diagnose my problem before I start removing things. Thanks for the website with the broken rack, that is what I think it is.
Thanks again to GunPowder and bazza77 for the replies and ideas.
Old Jul 31, 2019 | 03:04 AM
bazza77's Avatar
bazza77
I have rebuilt a tilt column so have had it all apart to change the 2 upper bearings , but never had a problem as you describe.
To get the two swivel pins out i just found a correct threaded bolt and put a washer on it and used a screw driver to lever the pin(s) out.
To release the steering lock plate I bought the tool from a local car parts shop , not expensive.. I also got an Allen head bolt to use to lock the tele part so the tool could be used. That's about all the "special" tools you need
They aren't that hard , but I had to have a few goes at getting the top housing back on without losing any bearings. I took mine out so I could do it on my work bench, sometimes 3 hands would be better but it's not too challenging.
Certainly wait and see if you get a positive answer on the cause , but it does sound like the problem is in the column.
One possible way is to get under the dash and look for any movement on the ignition rod.
If you can't see it one way to check is to remove the small cover under the column (trim piece) and just lower the column on the two mounting bolts a little and then see if your getting any movement on the rod
Old Jul 31, 2019 | 11:23 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
One way to make sure it's a rack problem is to put hand on the rod and turn the key, if the rod doesn't move then it's a rack issue for sure.
I can get you down the column past the turn signal switch with this paper I did years ago, but I've never finished the entire column write up. (yet). We've even shot a video that's still on hold. http://repairs.willcoxcorvette.com/w...stallation.pdf
There are some other good pictures on my tech page too... http://repairs.willcoxcorvette.com/?...teering+column
And if you do tear it apart, there are enough people here that have done this job that I'm sure we can walk you through any issue you have.
Old Jul 31, 2019 | 11:32 AM
70s Vette Guy
Thanks, I appreciate the ideas, removal instructions and pictures. I'll be pulling it soon, wife wants her car back.
To Key in steering column clicks
