71 wiper door function
Old Jul 31, 2019 | 04:06 PM
Rick Classen's Avatar
Rick Classen
7th Gear
Default 71 wiper door function
have friends 71 over and wiper door comes up when starting, stays up after car is turned off..installed new wiper arm vacuum switch now comes up then down when starting would like to know if the up and down is normal when first starting...stays up if wipers are on as well as the manual vacuum control
Old Jul 31, 2019 | 04:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Rick Classen
...would like to know if the up and down is normal when first starting...
No. Check the metal valve and the white plastic filter.
Old Aug 1, 2019 | 10:24 AM
Rick Classen
7th Gear
changed all three wiper arm vacuum switch, vacuum hose check valve and vacuum hose filter, was told possible vacuum leak or is it the vacuum relay valve
Old Aug 1, 2019 | 01:27 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Vacuum relay would be my guess.
Old Aug 1, 2019 | 04:40 PM
theandies's Avatar
theandies
Classic wiper door solenoid issue. Clean or replace it. It is located on the back of the tach.
Here is how to disassemble and clean.
Disassemble and clean wipe door solenoid
Old Aug 1, 2019 | 08:37 PM
C3 Stroker's Avatar
C3 Stroker
Did you test the new wiper arm vacuum relay switch before you installed it? All the new cheaper ones test bad. Only the one from Lectric Limited, (sold also by Willcox and now Ecklers) is good. Costs about $60.00 compared to $25.00.
Old Aug 2, 2019 | 10:06 AM
Rick Classen
7th Gear
Easy Mike the new metal valve was bad , only allowed 10" of vacuum installed another one and works like it should
Thanks Mike
Old Aug 2, 2019 | 10:08 AM
Rick Classen
7th Gear
C-3 Stroker bad metal vacuum reserve all 3 got from Ecklers Thanks
Old Aug 2, 2019 | 10:11 AM
Rick Classen
7th Gear
Thanks for all the help new part bad. it was reservoir check valve (metal vacuum valve)
Old Aug 2, 2019 | 10:48 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I have ordered two of these from two different places and both were impossible to suck any vacuum through...very little, like it was blocked.....put the original one back on.
Jebby
To 71 wiper door function
