Ignition switch push rod problem
Old Aug 4, 2019 | 06:03 AM
Markflorida's Avatar
Markflorida
1st Gear
Default Ignition switch push rod problem
Just got 1977 manual model and not starting from ignition switch. Where is location of starter relay, thanks !
Old Aug 4, 2019 | 08:44 AM
Duke94's Avatar
Duke94
Relay is on the starter.
Old Aug 4, 2019 | 11:39 AM
Peterbuilt's Avatar
Peterbuilt
To start the car turn the key to 'ON' and momentarily jumper from the 'main battery terminal' to the 'S' start wire terminal'.
To Ignition switch push rod problem
