Howling on deceleration after changing pinion seal
Sounds to me like the nut isn't tight enough to set the bearing preload.
There are a few ways to check, and each one gets more and more involved.
1. Disconnect the drive shaft at the pinion and see how much in and out play you have by hand, if the pinion has any feelable movement, tighten the nut just a touch more. A little nut turning goes along way.
2. Measuring with a magnetic base dial indicator.
Measure the in and out play, tighten the nut a tick. Re-measure, repeat until there is no change in your measurement. That would indicate that the bearing races are up against the crush sleeve.
3. Disconnect the half shafts also. Then using a dial torque o meter, tighten the pinion nut untill it takes about 5 in/lbs to turn the pinion.
May want to look at a manual for the correct rotatonal torque, I'm pulling this either from memory, or my a$$, don't know which. Lol
Option one is caveman, but if you have a feel for this kind of thing, works-ok.
Number two is more precise.
Three is probably best practice.
Don't forget to stake the nut.
As usual ymmv,
Good luck
Jeff
If you lost your marks and don't have a 0-30 in/lb dial TW you can back the nut off and bring it in until you feel it seat on the sleeve. Now if you are not sure of the correct "feel" this may be difficult to do and I feel this is shooting in the dark so to speak. If the yoke was moving around you may also wreck your new seal and have to start over. If the pinion is loose enough it will crash into the posi case on acceleration, which you will hear in most cases. When I open a diff and see the pinion marks on the posi case, whether light or deep I know the pinion seal will most likely not be the original green ones GM used, could be a CR/SKF seal but most times are red or orange.
There is another thread running here now on this same subject. I posted a link to pictures that will help you.
