Broken dipstick tube extraction
Old Aug 19, 2019 | 03:01 PM
DorianC3's Avatar
DorianC3
Default Broken dipstick tube extraction
I suppose this happened to many of us.
From whay I can tell, this was once a chrome tube. Flashing a light down there and it seems to be resting on a shoulder in the block. I tried pulling it out with a screw and tapping it out with a chisel.
I am going to buy some needle nose vice-grips and try with that.
Would collapsing the tube a bit help ?
MTIADC3
Old Aug 19, 2019 | 03:06 PM
sstonebreaker's Avatar
sstonebreaker
yeah, vice grips or a big ol' pair of channel locks might get it.
Old Aug 19, 2019 | 04:54 PM
HeadsU.P.'s Avatar
HeadsU.P.
This happened to another last winter. The posts went on for days. I don't remember what the solution was but maybe someone else can find the thread.
Sit tight for a day or so and see who responds. You don't want to break it off flush with the block.
Edit: I just remembered. I believe they bought a Vice Grip with a sliding hammer on the handle. Very clever. The tool was used for rivet removal. Don't know who sells it.
Old Aug 19, 2019 | 05:15 PM
derekderek's Avatar
derekderek
Stick a bolt in it and clamp vise grips on it. Then hit the vise grips from below with a hammer.
Old Aug 19, 2019 | 05:42 PM
Mooser's Avatar
Mooser
for a small block you can usually take a 3/8 (fine thread is better) bolt and thread it into what's left (grind a chamfer onto the end of the bolt helps get it started) and then pry it out or use a long bolt / all-thread and make a slide hammer type thing with whatever you have handy
I'd also stuff something (wheel grease?) into the pipe to prevent anything from going into the pan
M
Old Aug 19, 2019 | 06:41 PM
TimAT's Avatar
TimAT
I've had some luck just using an easy out.
Old Aug 19, 2019 | 08:15 PM
BarryB72's Avatar
BarryB72
Guilty as charged.
I could not swing a hammer hard enough and at the right angle from below with the car on the floor so unless you have access to a lift or ramps don't bother getting under the car.
I actually went through this twice in a matter of weeks.
I got the first one out by crushing the tube with vice grips then threading in a slide hammer into the end of the vice grips. It took quite a while to crush the tube but it worked. However......
I Then I decided I didn't like the tube I put in because it didn't look assembly line correct and I tried to pull it out with my slide hammer and it just ripped it apart at the block. Here I go again.
This time I just found a bolt that threaded into the broken tube, clamped the vice grips/slide hammer on the bolt and I had it out 5 minutes after I broke it.
I'll post pictures as soon as read some bedtime stories.
Old Aug 19, 2019 | 08:26 PM
HeadsU.P.'s Avatar
HeadsU.P.
I thought that WAS a bedtime story. And Barry lived happily ever after.
Thanks for the info.
Old Aug 19, 2019 | 08:58 PM
BarryB72's Avatar
BarryB72
From the first time in February.
Old Aug 19, 2019 | 09:01 PM
BarryB72's Avatar
BarryB72
Right now.
How nice I literally pulled it out and put it in a bucket. Never bothered to even take the bolt out.
If you want to go this route I can tell you how make one from hardware store parts.
Old Aug 20, 2019 | 01:46 AM
DorianC3's Avatar
DorianC3
Thanks gents. This helps a lot. I ordered a couple of vice grips. (Amazingly I don’t own any ) I feel confident with this feedback I’ll be able to extract the broken tube.
I’ll attempt again on Wednesday when the pliers come in.
Stay tuned.
Old Aug 22, 2019 | 04:19 PM
DorianC3's Avatar
DorianC3
Bought a tiny pair of vice grips. I had my son hold it steady and, getting under the car, I tapped it out with an extra long drift. It took me 30 seconds.
Old Aug 22, 2019 | 04:30 PM
BarryB72's Avatar
BarryB72
A helper .... need to get me one of those.
Old Aug 22, 2019 | 05:19 PM
HeadsU.P.'s Avatar
HeadsU.P.
Post owner: DorianC3
Issue: Broken dipstick tube.
Result: Removed / repaired, resolved!
# posts: 14
That will be $119.
How do you wish to make your payment?
Old Aug 22, 2019 | 08:26 PM
derekderek's Avatar
derekderek
not much dinero when it gets split between about 6 of us.
Old Aug 23, 2019 | 01:17 AM
DorianC3's Avatar
DorianC3
# posts: 14
That will be $119.
In beer and chocolate?
Old Aug 23, 2019 | 06:53 AM
derekderek's Avatar
derekderek
Can you say Grolsch? bet you can even pronounce it right.
To Broken dipstick tube extraction
Old Aug 23, 2019 | 08:30 AM
Kacyc3's Avatar
Kacyc3
what tube are you going to use to replace it? I have one I bought for a 79 and it wont fit my 400 from 73 ish.
Old Aug 23, 2019 | 08:32 AM
HeadsU.P.'s Avatar
HeadsU.P.
Perhaps SEVERAL ounces of each.
Old Aug 23, 2019 | 04:13 PM
DorianC3's Avatar
DorianC3
Meh - fluent in both French and Dutch... maybe ?
