EGR Solenoid Replacement
Old Aug 19, 2019 | 11:13 PM
VetteGuy64's Avatar
VetteGuy64
2nd Gear
Default EGR Solenoid Replacement
Hello, I have a 1981 Corvette with all of the emissions equipment still installed. I was replacing vacuum lines and found that the top EGR solenoid on of the pair had a broken inlet that had been glued together previously. I would like to replace both of these the lower can be replaced with a EGR solenoid valve from a 92 and I found instructions for that, but what about the upper? Can anyone tell me part numbers for anything currently in stock that I can use? You can see the two I am talking about below. Thanks for any help you can offer!
Old Aug 21, 2019 | 05:41 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I believe the lower one was 1997518 and the upper one was 1997517 which number changed to 1997536
I don't have any history on 1997518 but what I do know is that both fit Pontiac and Oldsmobile cars as well.
Old Aug 21, 2019 | 08:23 PM
VetteGuy64's Avatar
VetteGuy64
2nd Gear
Thank you for the information. I can't find the 1997518 part anywhere either. Do you know if the top one is for canister purge?
To EGR Solenoid Replacement
