New Owner Help
Old Aug 20, 2019 | 07:46 AM
Adriana1's Avatar
Adriana1
Default New Owner Help
Hi Guys
So I have just taken charge of my 1971 C3 Manual
Imported it from NYC, very happy with the car but a few ****les, hope some of you may be able to help
I need to have a decent workshop manual for the car, sure there will be things to fiddle and repair over the years so a decent manual is needed- any recommendation's please
Vacuum problems, the pas side headlight doesn't want to lift, drivers is OK but a bit slow, wipers and wiper door works fiune but no washers
Are the wares electrical??
No horn working- Electrical
Perhaps a fuse has displaced on the sea journey- where are the fuses??
Unsure what the little controls under the steering Colum are- looks like to pull switch's and 1 rotary switch?? any ideas
This is my new car how pretty is this
Old Aug 20, 2019 | 08:16 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I would recommend getting an Owner's Manual, the Factory Service Manual and the Assembly Instruction Manual. YouTube and corvette forums are also a great resource. What you save in labour you can put towards the purchase of tools.
On my '76, the under the dash **** is for resetting the odometer and the stem is pull switch for manual override for opening the headlights without turning them on.
Old Aug 20, 2019 | 12:19 PM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
As resdoggie said, get the GM Service manual.
For the Headlights read this:
http://www.corvette-101.com/vacuum.htm
For the horn go to www.willcoxcorvette.com
71 schematic:
https://docs.google.com/viewer?a=v&p...DcxZjZkOTdhNGU
Bergerboy's Avatar
Bergerboy
Welcome Adriana!
Beautiful chrome/chrome C3!
Where did you import the car to?
Ditto what Resdoggie advised: Owners Manual, Service Manual, and Assembly Manual (AIM).
Also, on those early C3's, the ***** under dash are as follows, left-to-right:
- Odometer reset **** - push or pull, and turn to reset the trip ODO to 000
- Left Headlight Door override **** ("L" = Lights is how I remember) - pull down to open the headlight doors and leave them open with lights off (originally for replacing bulbs, etc.)
- Center **** - Turn **** for stopping the wipers mid-stroke (meant for replacing the wiper blades in up position)
- Right Wiper Door override **** - Pull down to open the wiper door without needing to turn on the wipers
(both pull-down ***** work off of the vacuum, so the engine needs to be running to operate still, or you need to have good vacuum in reserve if engine is off)
Old Aug 20, 2019 | 02:59 PM
Adriana1's Avatar
Adriana1
Thanks guys
I am in the UK- Gloucestershire
It came yesterday and am now just doing some tinkering and sorting some issues out that come with a 50 year old car
Need to get my head around the vacuum controls and the way that works,
The car has had an engine replacement its got a 388 stroker motor, mechanically seems to be spot on
Painted and made to look like a Baldwin Motion car very cool I think
So the electrical issues I have is
No horn, No heater fan, No washers
I had the wiper door off today and looks to me like the washers have been disconnected as I cannot see any pipe work except 1 open ended pipe that comes from the wiper box area- also cannot find any sign of a washer bottle
So might have to make some modification to this
Old Aug 22, 2019 | 04:19 PM
wajulia's Avatar
wajulia
That 383 stroker engine may not have enough vacuum to operate the headlights and the wiper door. Check to see what the vacuum is.
Old Aug 24, 2019 | 04:48 AM
Adriana1's Avatar
Adriana1
Yes thats what I was wondering its also got the big cam etc with a 1050cfm Holley
May look to put a electric vacuum pump on
anyone had experience of this?
Thanks for your help on the way
Old Aug 24, 2019 | 11:47 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Your carb is way too big for a 383. A 750 would be better suited for a 383. What are your cam specs?
To New Owner Help
