Brake light problems
Old Aug 20, 2019 | 02:28 PM
travis1968's Avatar
travis1968
Cruising
Default Brake light problems
I have a 68’. The right side brake lights stopped working. Left side work and all 4 tail lights work. Bulbs work, I swapped right to left. Front directionals work. The right side blinker is sluggish but works. I cleaned up the grounds but nothing. Any advice would be appreciated. Thank
Old Aug 20, 2019 | 02:37 PM
Peterbuilt's Avatar
Peterbuilt
The sockets can corrode inside the plastic, attach a wire to a good ground and check by touching the wire to the brass part holding the bulb:
Old Aug 21, 2019 | 09:53 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Did you clean the socket and the connections inside. I'm having a recurring issue with this right now. I also had the corroded socket inside like was posted above
To Brake light problems
