1968 elec/vac issue
Old Aug 20, 2019 | 06:10 PM
GLJones's Avatar
GLJones
7th Gear
Default 1968 elec/vac issue
Still having problems with the "system", looking for suggestions. The vacuum system works for the headlights, however the wiper system (elec/vac) does not work? shorted out the wiper motor so I know it works, purchased new dash wiper switch...no wipers. What do I do next? Thanks for any suggestions
Old Aug 21, 2019 | 07:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
First item, is the wiper door opening when you turn on the wipers? Wipers will not power on if the door isn't open.
Old Aug 22, 2019 | 07:27 AM
jpatrick62's Avatar
jpatrick62
Ensure that the wiper dash override switch (round **** sandwiched between the wiper door and headlight overrides) located under the steering column is not causing the issue. Turn it clockwise to see if the wipers will engage.
Old Aug 22, 2019 | 04:38 PM
SwampeastMike's Avatar
SwampeastMike
I'm not sure about the exact location but if the wiper door is open but the wipers won't run there's an electric limit switch that senses the door is fully open. It's mounted on the firewall. Make sure it's present, that the button is pressed and that it actually works. Just a simple SPST NO switch so make sure it conducts with the button pressed.
Old Aug 22, 2019 | 06:10 PM
GLJones's Avatar
GLJones
7th Gear
Thank you for the input, I will give those suggestions a try first opportunity.
To 1968 elec/vac issue
