Power Steering Pump
Old Aug 22, 2019 | 06:10 AM
rodney25's Avatar
rodney25
Default Power Steering Pump
Hi All,
Have a strange question. Have a 1975 350 4speed. Power Steering pump is leaking. I have a 305 engine with a good power steering pump. The 305 pump fits the 350 engine.
Question: will the power steering pump from the 305 engine be fine or do I need the pump for a 350 engine and why? The 350 pump is tear drop shaped but the 305 is round on the bottom with a tube neck.
Any help is greatly appreciated.
Old Aug 22, 2019 | 08:03 AM
Mooser's Avatar
Mooser
I seem to recall Jim Shea suggesting that if you swapped pumps you keep the pressure valve from the vette and put it in the other pump
That said, re-sealing your original pump is a pretty simple job and the o-ring kits are cheap.
M
Old Aug 22, 2019 | 08:14 AM
HeadsU.P.'s Avatar
HeadsU.P.
I don't believe the round style Saginaw fill tube & fill tube cap will clear the ALT bracket. The tear drop or pear shape fill tube cap is really close to the bracket as you know.
Old Aug 22, 2019 | 08:46 AM
gjohnson's Avatar
gjohnson
The round one will clear the alt bracket but might not fit the Vette PS bracket.If the threaded mounting studs are in the same spot it will work.
Old Aug 22, 2019 | 02:58 PM
rodney25's Avatar
rodney25
Hi All,
The pump fit the bracket and had to swap the screw that the hose bolts to but works fine.
To Power Steering Pump
