76 with mini starter.
Old Aug 23, 2019 | 07:07 PM
rayluka's Avatar
rayluka
Default 76 with mini starter.
Does anyone know the proper wiring for a mini stater on a sm block 76? I connected it the same as the factory and when I hooked the ground up it started cranking. And yes the small wire is connected properly to the solenoid..
Old Aug 23, 2019 | 09:57 PM
Kid Vette's Avatar
Kid Vette
Chevy Ministarter Installation Instructions
Old Aug 23, 2019 | 11:13 PM
jackson's Avatar
jackson
http://www.solenoid-switch.com/Delco...datasheet.html
Starter Solenoid connections for GM w/ HEI distributor:
large M stud connects Directly to Motor housing ... this connection made at Starter factory ... nothing else connects here
small S stud/terminal connects to switch
large B stud connects Directly to Battery's + pos post
* No Ground or Negative connects to solenoid ... None *
* Battery's - neg post connects Directly to frame/chassis ground *
Old Aug 24, 2019 | 12:38 AM
Gunfighter13's Avatar
Gunfighter13
Sounds like you hooked the battery cable up to the wrong post. Post a photo of the starter connections.
Old Aug 24, 2019 | 05:36 AM
derekderek's Avatar
derekderek
unhook the small wire from the solenoid. hook up ground wire. still cranks? bad new starter. doesn't crank now? need to see what is up with the wire that fires the solenoid.
To 76 with mini starter.
