need more hp for my 74
Old Nov 11, 2002 | 08:37 PM
TRAVIS74's Avatar
TRAVIS74
Default need more hp for my 74
I have a stock 74 L-48 and I am looking to increase the horsepower to around 300 can anyone suggest what might be a good setup for this any help would be great thanks Travis
Old Nov 11, 2002 | 08:38 PM
QuickVet's Avatar
QuickVet
Default Re: need more hp for my 74 (TRAVIS74)
just get a vortec top end :D
Old Nov 12, 2002 | 02:20 PM
Alwyn678's Avatar
Alwyn678
Default Re: need more hp for my 74 (QuickVet)
Sure just read my mods.......Cam ....Heads...Carb...Exhaust(headers+2.5 duals+ h or x pipe) :yesnod:
Old Nov 12, 2002 | 10:27 PM
tnt76vette's Avatar
tnt76vette
Yeah, just see my signature......Still running stock 882 heads and it DD's at 300 (well, almost anyway!) HP. Much more driver grinability with this motor over stock....prob. can hit 325-350 w/the right heads, but for right now, I LIKE it as it is....... :cheers: :cheers: :cheers:
Old Nov 13, 2002 | 12:57 AM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Travis...
I gotta admit that GM shortchanged us with horsepower on the 74's on out. Look at your console plate... they even left it off there as they had to be embarassed with 190 hp. :sleep:
The only real way that I know of obtaining the horsepower with integrity is to pull the intake, heads & cam. From there you can do just about anything. It's nothing to get to 300HP if you have a few bucks and some time. Punch out the pistons & go to 9:1 or 9.5:1... a mild cam... and a definite to go to double valve springs with dampers. The valve train is the most important thing.
Old Nov 13, 2002 | 01:30 AM
aharte's Avatar
aharte
My plan (as of yesterday :) ) is to add AFR190 heads with a strong light valvetrain, strong springs (maybe rev kit too), etc, lifter, and weiand stealth intake. Demon carb and MSD ignition (want tach drive back) too. Desktop dyno claims ~500 hp@6500 rpm/450 ft-lb@5200 rpm on my stock L82 cam. I don't think the L48 cam has much potential, so you should ditch that. Also make sure your exhaust flows well if you want to go the high rpm route. Some people prefer low-end torque, which would need a completely different setup.
Old Nov 13, 2002 | 09:25 AM
Alwyn678's Avatar
Alwyn678
Default Re: need more hp for my 74 (aharte)
It will not be close to 500hp probably around 375 to 400
Old Nov 13, 2002 | 09:53 AM
aharte's Avatar
aharte
Default Re: need more hp for my 74 (Alwyn678)
Really? I meant gross hp, so 375-400 RWHP would sound reasonable. I'm just starting to learn about this stuff, so if that's not what you meant, then please explain.
Old Nov 13, 2002 | 10:00 AM
Fevre's Avatar
Fevre
To make 500 horse at the fly wheel, which is gross hp, you will have to build a very high comp eng that runs 6000+ rpm's. The 375-400 horse Alwyn states is pretty resonable and is about what I am producing.
To need more hp for my 74
