Hydroboost question
Old Aug 26, 2019 | 08:34 PM
atthemattin's Avatar
atthemattin
Default Hydroboost question
So I don't really know what to think about this. I bought a rebuilt hydroboost, a rebuilt pump, and I rebuilt my own control valve and a new willwod master. Here's the problem. I'm getting brake power, but it's not locking up the wheels. It stops the car, but not as quickly as I should. The weird part is, I could cut the wheel and with the pressures on the brake, I can get more brake power. But, when it's going straight, I'm not getting strong braking. Any ideas?
Old Aug 26, 2019 | 10:19 PM
nyciti's Avatar
nyciti
Sounds like you have air in the system, did you bleed it?
Old Aug 27, 2019 | 12:33 AM
atthemattin
I thought I did. If that's all that would be great. How much do I have to bleed it? Have any tricks?
Old Aug 27, 2019 | 05:43 AM
mrvette's Avatar
mrvette
I would assume you turned the wheels full right to full left a few times, and hit the brakes several times, I happen to have a serp drive on my 350 engine, and a rack steering setup that preceded the HB install, I just used a T fitting in the return line to the canister on the frame, the one on a V belt drive would of course be on the pump.....same diff.....
Old Aug 27, 2019 | 06:46 AM
nyciti's Avatar
nyciti
Jack the front wheels up and turn left / right full lock at least 30 times...the hydroboost systems take a while to bleed as they sit higher than the pump so you really have to work to get all the air out.
Old Aug 28, 2019 | 09:50 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Which brake pads are you running?
To Hydroboost question
