Isn't there an aftermarket IRS kit out there built to handle the higher power apps?
Or can't a late model Mustang IRS be fabricated to fit a Vette?
I am sure there are plenty of rolled GT-350's in wrecking yards that the parts can be sourced from??
Anything can be made to fit, just a matter of cost and your ability. There are threads here about grafting Camaro suspension on and ford IRS in the last year or so.
There are some kits available to bolt in(modifications are ness I'm sure) but the costs I have seen are high. A solid axle swap can be done and is probably the cheapest option if you want a stout rear axle setup.
I would do a search on this forum, but off hand the Tom's, 12-bolt conversion of the existing setup was one of the few options for the existing, stock setup. Not sure if he is still in business. I have also seen a few custom 9" IRS setups as well as conversions to C4 rear ends. I also bought a Dragvette bracing system at one point but then sold it; never did install it. It was a lot of money for something that didn't strengthen the ring and pinion though.
You can spend a huge amount of money trying to strengthen the existing setup, but I question the bang for the buck. Heavy duty offset trailing arms, cryogenically treated axles, heavier halfshafts with heavier ujoints, halfshaft loops for safety, Dragvette bracing kit, much stiffer spring etc. In the end the ring and pinion and carrier isn't any stronger and you still have halfshafts that move up and down.
David
Tom Watt passed away almost 2 years ago, RIP. However his family is running the business and the parts are available. The good 10-17 x 30 HT spiders are the one part that is gone, there are current 10-17 x 30 spiders on the market but not like those Tom supplied for 40 years.
As mentioned anything can be done all depends on your budget. The newer diffs on the market are in the $10k range I believe, worth more then some complete cars and who knows ROI on these.
Tom's kit is the most reasonable one if you want to keep IRS. If you can do all the work you will save a lot of money but the parts will still cost you about $5k. Even the 9" kits are up there, I think the last one I heard quoted was about $5k all in. If you sub out the work be very careful, there is a recent thread here of a 12 bolt that lasted a good 2500 miles before if came apart in a very bad way.
Here is one I did on my garage floor about 10 years ago. You do have to modify your tunnel quite a bit between the two boxes behind the seats to make it work though, fyi.
A 10k diff is out of the question, I'll sell the car before I have to put that kind of money into the diff. Even 5k is a bitter pill to swallow but that would be the absolute max I'd want to spend on it. How much is the 12 bolt conversion? How much is the 9 inch conversion? How much is the solid axle conversion? I can do the install work myself and save money there. Any links to where to get the parts and links to articles on how to do these conversions?
I can't get the link to work right, sorry. Do a search for "Autofab 4-link" and you will get several. My whole kit was around $5k, but 10 years ago. I did the work.
That is what I did , By far the best choice. I can transfer weight making the car 23 / 27 / 25 / 25 percent distributed to the 4 corners. Its a front loader making service simple. Its a Fab 9" housing . 4 Link w/disc brakes . Its 100% the best solution of all imop.
GTR1999, can build you a quality rear diff, Van Steel is also selling complete units and Mike Dyer is building my rear diff.
The costs to upgrade my rear diff to a HD ten bolt will run around $4,000.00 in parts alone including: all new components on the inside, Tom’s 3 1/2” HD half shafts, u-joints, outer axles, and everything to set up my trailing arms.
Labor for, machining, polishing and assembly is additional.
I’ll be running this behind a 496 / TKO-600RR (.82 od) with 3.08 gearing.
If you go with a 12 bolt you will be stuck using 3.73 or 4.11, or taller rear gears.
If you go with the 12 bolt you won't necessarily be stuck with 3.73 or taller gears, I mean, after all, doesn't a 3.73 gear need a 3 series carrier? If I'm not mistaken you need to go with a 4 series carrier when the gear ratio is 3.90 or higher so the 3.73's should need a 3 series carrier. I don't want tall gears in my car, it has 3.08 gears right now and I want to keep that ratio. I don't want tall gears with a supercharged big block because for one it doesn't need them (the car is frighteningly fast already) and for two the gas mileage is bad enough as it is right now, no need to make it even worse. Also, the speed limit on the highways out here is 75mph and I don't have overdrive. Trying to maintain that speed with a 3.73 or larger gear and no overdrive would suck, it would run hot and eat gas like it's going out of style.
Tom’s 12 bolt conversion called for a Series 4 case, and only came in 3.73 and up!
Has anyone tried Dragvette's rear end? They're offered with either a posi or spool, and they claim the posi build will handle up to 650hp. They're also making their own 30-spline inner axles they claim are stronger than Tom's.
Anyone interested in going to a custom diff has to do their due diligence. Get pictures of all the diff's showing the internals and setup. compare them to each other to see the differences, educate yourself on what parts should be used and ask to see them. Do not go by a build name since some use a common name and cut corners in the build. No pictures, buyer beware, This is not a one size fits all application and those who bought titled builds for a great price most likely don't even know what they got.
Some of the axles are hardened throughout the unit, instead of just surface hardened. The Mark Williams guys just released some 4340 axles, but they are $750 roughly apiece. A limited custom order run. Tom's on the 1480 units, had about 3 sets of axles hardened throughout, one of the pictures of my spares shows those units.
A 3.73 gear won't work on a 4 series carrier without a ring gear spacer. I don't see any reason why a 3 series carrier can't be put in place of a 4 series carrier, the only difference between them is the thickness of the flange that the ring gear bolts to. They are physically the same size, have the same dimensions, use the same carrier bearings, same spider gears, etc. The only difference is the in the flange for the ring gear. A 2 series carrier has the thickest flange, a 3 series. carrier has a thinner flange, and a 4 series carrier has the thinnest flange because the thickness of the ring gear gets thicker as you go up in gear ratio.
The 12 bolt vette conversion uses a machined 4 series case so it's neither a 4 or 3 series. The 12 bolt R&P is a special grind set, unless you go real old school and machine a stock set of gears as they were originally done 45 years ago. Whlle I have the prints to do that I wouldn't bother. 373 411 or 456 are the only ratios. Some old 355 were made by Tom many years ago but that was pushing it and I don't recall him offering that ratio.
Didn't someone post a 12-bolt option for you? Did the deal not work out? Not trying to be nosy, but it seemed like that might work out for you. I would have snatched that up if I hadn't already converted to the 4-link setup.
