BB Fan shroud
Having the shroud cover the whole radiator won't give you anymore cooling when moving but will direct more air through the radiator when stopped and the fan is running. In 68 the original BB radiator shroud design was just a sheetmetal ring that did not cover the whole radiator. After overheating problems on the early cars they quickly redesigned the cooling system and replaced the sheetmetal ring shroud with a full cover fiberglass shroud to help airflow over the radiator when stopped.
John
JC68-- that is exactly what is on m 69- a sheetmetal ring. Which is why I'm exploring other options.
The general rules for early c3 cars are:
The fan shroud choice is easy.
-Aluminum radiator cars used a sheetmetal ring fan shroud. -L88 cars are the exception as they did not use a fan shroud with the AL radiator.
-Copper radiators cars used a fiberglass or plastic fan shroud. Early 1968 cars are the exception to this, they used the sheetmetal fan shroud on copper radiator cars as well.
The basic radiator rules are:
- Aluminum radiators were used unless the car had one of the following options:
- BB engines used a copper radiator. -L88 cars are the exception
- Cars with auto transmissions used a copper radiator. - The copper radiator had provisions for a built in transmission cooler.
- Cars with A/C used a copper radiator.
1969 L46 cars are the ones that break the radiator rules. GM used both aluminum and copper radiators on cars with manual transmissions for no apparent reason.
