Heater core tester
Old Sep 10, 2019 | 12:18 PM
kodpkd's Avatar
kodpkd
Default Heater core tester
Now I know why someone bypassed my heater core.... Seems to leak.. Tested with my Bubba tester.
Old Sep 10, 2019 | 04:19 PM
L-46man's Avatar
L-46man
Did you 'soap bubble check' your tester????
Not so 'bubba', that's how I would've done it...leak down test.
Unkahal
Old Sep 11, 2019 | 12:11 PM
kodpkd's Avatar
kodpkd
Yes,,,, I got the soap water out and tested the best that I could. It was hard to see the connection at the heater pipes. I did about 8 PSI and it blead off is seconds. You also need to be very careful not to explode your core. I used a bike hand pump. If you use an air compressor it's very easy to get to much pressure.
Old Sep 11, 2019 | 01:23 PM
L-46man's Avatar
L-46man
Absolutely don't overpressure! The Radiator cap and therefore the system is rated to 15psi...so just short of that will give the best results....I figure should hold pressure for 24 hours.
Probably blown.
cheers Unkahal
Old Sep 11, 2019 | 01:57 PM
derekderek's Avatar
derekderek
Make sure you leak test your leak tester. Maybe put both ends on to a piece of copper tubing and blow it up and see if it holds. Is the heater core still in the car? If not get something like in oil drain pan or something else big enough fill it with water and plunk it in there.
Old Sep 11, 2019 | 02:53 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Good idea! I have a new heater core to install and I sure don’t want to find out that it leaks after that ordeal.
To Heater core tester
