Mechanical Advance Distributors
Old Sep 11, 2019 | 10:23 PM
eddp's Avatar
eddp
Default Mechanical Advance Distributors
Are mechanical advance distributors all point and condensor or do they have HEI mechanical without a vacuum advance?
Old Sep 12, 2019 | 07:09 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Every distributor has a mechanical advance setup in it. I am not aware of any HEI that comes without vacuum advance. Why do you not want one?
Jebby
Old Sep 12, 2019 | 07:27 AM
3X2's Avatar
3X2
Jebby
In another post, OP is having an engine built. He is planning to eliminating the ecm, ecm controlled distributor and carb. Engine builder is insisting on using a mechanical advance only distributor.
Old Sep 12, 2019 | 07:37 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I would find another engine builder. Sounds harsh, but there are sure a lot of people out there that think they can reinvent the wheel.
If the builder “insists” on it, have him give a solid reason why.....
Jebby
Old Sep 12, 2019 | 07:43 AM
3X2's Avatar
3X2
I agree with you. I have told the OP this on another forum.
Old Sep 12, 2019 | 10:25 AM
derekderek's Avatar
derekderek
No vacuum advanced works just fine. In a boat, and at the drag strip. Any setup where you actually want to continue going after you've lifted you foot off the gas, you have to have vacuum advance or some kind of computer controlled part throttle advance.
Old Sep 12, 2019 | 11:07 AM
gg521's Avatar
gg521
I have a MSD distributor that does not have a vacuum advance.
Old Sep 12, 2019 | 12:13 PM
eddp's Avatar
eddp
Does the MSD mechanical w/o vacuum advance have points and condenser, or is it electronic?
How does it perform at low RPM's or when you take your foot off the gas?
Old Sep 12, 2019 | 12:53 PM
jim-81's Avatar
jim-81
You can just use a regular distributor and NOT USE (i.e. don't hook up) the vacuum advance.
Old Sep 12, 2019 | 01:20 PM
eddp's Avatar
eddp
What's happening, is that the guy building my engine, says he is going use the existing ECM distributor in the '81 Vette and convert it to mechanical advance to run the ECM deleted engine. He is putting an AVS2 Edelbrock on a 2701 intake and instead of a regular HEI dist, he is going to use the stock distributor with a kit to convert it.
Old Sep 12, 2019 | 01:56 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You can buy a brand new “mechanical” HEI from Rock Auto for $75.
Converting the distributor to mechanical and leaving out the vacuum advance is not a good plan.
https://www.rockauto.com/en/catalog/...stributor,7108
Purchase the new distributor....install and time it correctly and hook the vacuum advance to full manifold vacuum....you will thank yourself later.
The vacuum advance is there at idle and under light load conditions to help boost mileage and responsiveness and it is a big deal on a street car.
Jebby
Old Sep 12, 2019 | 03:23 PM
C3 Stroker's Avatar
C3 Stroker
My HEI does not have vacuum advance. And it has a tach drive. Davis DUI makes them if you want one. They will also custom curve it for you.
Old Sep 12, 2019 | 03:26 PM
eddp's Avatar
eddp
Maybe this is what the builder is intending to do? Convert my present stock dist into one like this. How is the low rpm performance and fuel milage?
Old Sep 12, 2019 | 03:35 PM
C3 Stroker's Avatar
C3 Stroker
A distributor like mine is not for low RPM or fuel mileage, neither of which matter to me. Strictly high performance street/strip application here.
Old Sep 12, 2019 | 05:10 PM
jackson's Avatar
jackson
OP
Don't let him bastardize-rig your '81 HEI ... get another one like was OE on '75 thru '80.
Most street motors with carb and No computer need Both Mechanical & Vacuum advances ... as '75-'80
Old Sep 13, 2019 | 10:57 AM
gg521's Avatar
gg521
Its electronic. There is no problem with lifting your foot off the gas. Everything performs well.
Old Sep 13, 2019 | 11:34 AM
MelWff's Avatar
MelWff
Default Fuel Mileage?
If you are concerned about fuel mileage and low rpm performance you will need a vacuum advance distributor.
To Mechanical Advance Distributors
Old Sep 13, 2019 | 02:45 PM
OldCarBum's Avatar
OldCarBum
The engine builder helping me set up my 496 discouraged me from going with just mechanical advance on my MSD.
He said he can set it up to work, but told me that since I’ll be using my car on the street, I and the engine will be much happier with the vacuum advance set up.
You are getting excellent advice here from those who are professionals in their field and really know these cars.
I never used vacuum advance on my drag boats, but racing is a whole different animal than street driving, even if you plan on driving it hard on the streets.
Old Sep 13, 2019 | 06:16 PM
eddp's Avatar
eddp
Default All is Well
I went over to the builder and he wasn't there. Spoke with the mechanic actually doing the build. He agreed with me that the dist should be vacuum advance. The owner has a high performance, racing mentality and I got it across to the mechanic, and he agreed, that I want a good efficient driver that has a little extra initial acceleration and decent milage.
Probably going to have around 12 initial with 32 total.
Old Sep 14, 2019 | 12:07 PM
MelWff's Avatar
MelWff
Default 32 total?
Why 32 total?
are you using aluminum heads?
what compression ratio will the engine have?
