Amp meter stoped working
Old Sep 13, 2019 | 03:06 PM
H8 mondays's Avatar
H8 mondays
Default Amp meter stoped working
I have a 76 coupe with the 350 and on the way home last night the amp meter just stopped working. I know it has a fusible link in the wiring somewhere but i have no idea where to start looking for it. Any help would be great.
Thanks in advance
Phil
Old Sep 14, 2019 | 07:48 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would pull the meter and check voltage at the wires coming in respect to ground, not each other.They should both show voltage which will give you the wire to look at. Most likely the gauge itself failed. Then replace it with a volt gauge. I for one resistd that for 4 years before I finally gave in and wwish i changed it earlier. Its a better tool for trouble shooting alternator or battery issues
Old Sep 16, 2019 | 09:54 AM
H8 mondays's Avatar
H8 mondays
While i can appreciate the upgrade to a volt meter over the amp meter I would like to start the wiring battle with the easy stuff first like fuses and fusible links. Due to my wiring harness being wrapped from start to finish the location of the fusible link is what I am looking for as it is located on the firewall behind the distributor or where ever. Thanks for the suggestion but removing the gauge cluster will be my last option.
Phil
Old Sep 16, 2019 | 03:28 PM
henrikse's Avatar
henrikse
my 73 ammeter quit and there is a fusible link middle of the firewall (between center and wiper motor. Easy to get at
Old Sep 16, 2019 | 03:45 PM
TCracingCA's Avatar
TCracingCA
When these Amp meters start having problems, I would get to that pretty quick for safety!!!!!
Old Sep 17, 2019 | 09:37 AM
H8 mondays's Avatar
H8 mondays
Thank you that is the info I was hopping to find without having to undue a lot of the wiring harness.
Old Sep 17, 2019 | 09:39 AM
H8 mondays's Avatar
H8 mondays
I have not driven the car since I got it home and I have a disconnect switch on the battery so I think I am good until I can get back under the hood. Thanks
To Amp meter stoped working
